Question about Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor
Computer says speakers working but no sound coming out have tried changing power outlet &input to computer conection evenchanged speakers .
    President:
  • 1,768 Answers
1. check the volume control in the task bar to see if you have the volume off
2. check the cable to the sound card.
Posted on May 01, 2010
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
My B/A 735 speakers were working fine then a hum started for a day or 2 & they totally quit working. Power supply is OK & other speakers work on my computer. Where can I get the control board...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps don
Mar 11, 2011 | Boston Acoustics BA735 Computer Speakers
Only 2ch sound on sony strde898
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio. I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
Sep 22, 2009 | Sony STR-DE898 Receiver
I have HP Multimedia Speakers. No sound comes from speakers. computer says Realtek digital output...Realtek high definition audio working.
If your speakers are powered speakers i.e. they plug into a wall outlet\has a red power LED etc...then unplug the input wire from your computer. Turn the volume all the way up on the speakers. This'll sound silly but it works. Lick the tip of your finger and tap the input wire tip with your wet finger. You will hear a "Pop" come from the speakers every time you touch the input wire to the speakers. This tells you the speakers are working and your computer is to blame. Good luck!!
barneyluc
Oct 02, 2008 | Audio Players & Recorders
I would like to know if I can use my Polk speakers on a Compaq 510 Evo c.p.u.
please check its compatibility in the user manual, if its going to work on your present OS or platform. then if its plug and play. And better check if the Audio input/output plug is compatible with your soundcard outlet at the back of your computer if so, please try to insert then have it tested if this will make sound...
Aug 04, 2008 | Polk Audio Computers & Internet
Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Feb 01, 2008 | Audio Players & Recorders
Sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Dec 31, 2007 | Kenwood SW-303 Speaker
No power to speakers
Lol, sounds like that iPod sucked the power out of your house. Just kidding. If it is plugged into a wall outlet, make sure that the conections are not bent or warped in any way (remeber this stuff is very fragile so look for the smallest stuff). If it is plugged into one of those multi outlet devils, make sure that is not too clogged up. For those I always use the Male Bathroom Ediquate rule, never stand (nor plug) next to a guy in another urinal.
Jun 06, 2007 | Altec Lansing iM3 Computer Speakers
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Computers & Internet Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
