Question about Raymarine Boating
Raymarine c70 scanner not rotating
Hello,I have a raymarine c70 with radar dome.
Now I have a problem,he,s not scanning.
On the display after starting the scanner appears;scanner is not rotating.
Cables and connections are fine.
Is it possible the driving belt of the scanner?
mohammed387
  • 1952 Answers
SOURCE: raymarine radar won't power up
click tis link and download manuals..in tat everythin was present...even service center details and warranty limitation are also available..if ur product in warranty period...contact service center and clear ur pro...its the best way i suggest
http://www.raymarine.com/SubmittedFiles/Handbooks/c_series/81221_4.pdf
thanks for usin fixya..rate tis solution
Posted on Sep 14, 2008
MarineTech1
  • 76 Answers
SOURCE: Antenna not rotating
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
Posted on Sep 03, 2009
  • 111 Answers
SOURCE: Hi, I have a Radar Screen. Furuno 1942 MK2 . What
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Posted on Oct 31, 2009
TechnoMarine
  • 132 Answers
SOURCE: Hi, Furuno 1731 radar - no sweep/echo seen on
Go to longest range and full Gain min Rain and Sea Clutter
Do you have speckle? Yes = Receive OK, Wiring OK,No transmit (magnetron or modulator) No = Most likely a broken wire
There is a very tiny coax (shielded wire) that is know to lose its' center conductor, which is very delicate
Posted on Jan 13, 2010
TechnoMarine
  • 132 Answers
SOURCE: furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
Raymarine radar won't power up
Check the wiring to the scanner, eventually test with a multimeter the volt at the scanner, so to find out if the scanner is getting power.
If wires testing reads ok, then probably you have a faulty scanner, and you need to replace it.
Sep 14, 2008 | Boating
May 11, 2009 | Boating
Furuno radar antenna not rotating
Apr 06, 2009 | Furuno 2.2kw 18" Radome
Plotter Rl70c no image
sounds like it died...i happen to have one for sail with 4k dome
Sep 19, 2008 | Raymarine RL70CRC GPS Receiver
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
Raymarine G series radar
Your problem is likely noise from the motor. Modern diesels use high speed networks, so it could be interference. Next likelihood would be a software issue. Is the diesel set up to display info on the G display?
Solution could be re routing cables, grounding or un grounding devices. First step is to send your processor to Raymarine, sorry, necessary step to eliminate hardware failure. This is a tough symptom, so do the easy stuff first.
Jun 16, 2008 | Raymarine C80 GPS Receiver
Raymarine SL70 Radar; Unit switches on normally, but there is no radar image appearing. The cable is ok, the scanner is rotating...
I have the same problem. All functions and settings appear to be working OK but no image. After startup time about 3.5 amps are drawm When I turn on power [transmit] amps goes up to 4.5 approx.
I have the scanner head spinning but no target images
Ian
Apr 07, 2008 | Raymarine RL70CRC GPS Receiver
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Boating Logo
199 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
