Question about KitchenAid KGSA906PSS Gas Kitchen Range
When we try to turn the oven on .. it says stuck key .. how do i
Why does the messgage stuck key come up and how do i fix this?
    President:
  • 949 Answers
That is referring to one of the buttons on the control that surrounds the readout screen. The only way to repair the problem is to replace the keypad.
Some KitchenAid products warranty the electronics for 5 years. I would check with KitchenAid before spending any money on it.
Posted on May 01, 2010
My oven screen said stuck key.I cant use the oven what i should to fix it?
1st thing , unplug it wait a few minutes then reconnect it
2nd thing feel with your finger the tactile buttons on back for any of them that feel depressed or farther in than others , this is most likely your stuck key
Oct 20, 2015 | Maytag Gemini 30" Self-Cleaning...
Countdown dial swich does not move stuck
please see the next topic and proceed according with common sense.
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right parts.
God bless you
Sep 07, 2012 | Microwave Ovens
When I try to turn the oven on it flashes F3
F3 is usually a stuck key on the keypad, try taking a hairdryer about 3-4 inches away from the keypad and heat the whole thing up about a minute. Wipe your hand over it and see if that doesn't fix it for you. If it does grea but you might have a bad touchpad and will need to replace it eventually. I
Jul 24, 2011 | Microwave Ovens
Have JKP86 oven and the controls on the oven do not work. Get an F7 error code
The F7 error code on GE ovens indicates either the control has detected one of the key pads on the interface/control is stuck or the clock ( ERC ) itself is faulty.
The first step in determining if it's simply a stuck key pad is to push the cancel/off key ( If you haven't already ). If that fails to clear the error try to shut off the 40amp breaker to the range at the service panel, leave it off for several minutes and upon resetting it the error will either return or the issue was a stuck key pad and you're good to go.
If the error does return after turning the power back on, you'll likely require a new ERC ( clock/timer ) unfortunately.
Hope this was helpful in moving you forward. Thank's for visiting "fixya" today and good luck.
Please take a moment and rate the information provided here accordingly.
macmarkus :)
Apr 10, 2010 | GE JKP86 Electric Double Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Kenwood elite glass top range shows error code F7 for all burners.
F7 indicates a stuck touch pad key. Try pressing all teh buttons on the key pad to see if one is stuck. If you don't have a stuck key, there may be a problem with the key pad module itself
Mar 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Jan 11, 2008 | Thermador SC302T Electric Double Oven
KitchenAid KGSA906PSS Gas Kitchen Range Logo
172 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
