Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Remote access I have a Linksys BEFSR51 and running xp pro on both computers. What ports do I need to forward on the linksys? tOmmy
  • 55 Answers
You would need to forward port 3389 and make sure that the ip you're forwarding it to has remote desktop enabled for at least one user.
(start--> settings--> control panel--> system--> remote desktop)
Posted on Mar 25, 2008
SOURCE:
How do I get my router add a new port forwarding entry - port 12345, protocol TCP. And how do I find out the IP address of my computer? Thank you for you your assistance.
To find the IP address your computer is using:
Windows XP/7
1. Click on Start > Run
2. Type cmd and hit enter
3. Type ipconfig and hit enter
4. The number on the right of IP Address is your assigned address.
To add a port forwarding entry, log into your Linksys device and try the following:
1. Click on the "Applications & Gaming" Menu
2. Input an application name (Can be anything you want)
3. Enter the desired port number [12345] in both External and Internal Ports
4. Choose the TCP protocol
5. Enter the last number of the IP Address in the box
6. Click the Enabled check box
7. Click on un7bpgedqyopdk0zbwaaaabjru5erkjggg== on the bottom
Sample of Port forwarding menu
vnplpartunolz7n6n3b9m+jnn7ml0i2nqxyrocyd25orpdehebgvt+6hh5hgnu0+edcks7p0pdwicsaoso4igridejiaikycxiwjccv4h6gesrve+m0iaaaaasuvork5cyii=
May 03, 2011 | Linksys WAG200G Router
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Port forward 5900
You can follow the steps here on how to forward port 5900 to your router, just go to this link http://portforward.com/english/routers/port_forwarding/Linksys/WRT54GSv4/RealVNC.htm
Jan 05, 2009 | Linksys Wireless-G WRT54GS Router...
Port Fowarding for my Logitech Webcam
Do you know how to do portforwarding in general?
Have a look at the manual - page 21. You can also find it here: ftp://ftp.linksys.com/downloads/NA/userguide/WRT310N_V10_UG_B-WEB.pdf
You should give your computer a static IP address (or enable static DHCP), otherwise the forwarding will fail if DHCP assings a different address to your computer.
Important is that you have two entries, one for port 8888 /TCP and a second one for port 8081 /Both.
If this helped, please come back and leave a comment, to help others with the same problem.
Dec 27, 2008 | Linksys Wireless-G Broadband Router
How do I port forward?
You can go to the link below then select your router model number. It will give you a step by step
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Nov 15, 2008 | Linksys Wireless-G Broadband Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Forward ports in linksys wrt45g so magicjack will work
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Oct 05, 2008 | Enterasys Distributed Forwarding Engine...
Cant open a port
Open up internet explorer and type:
192.168.1.1 into address bar and press enter.
A login box should appear.
If you haven't changed the password, the default should be
User name - leave blank
Password - admin
Once onto router home page, click on 'Application and Gaming' tab.
Name the port (whatever you are using it for)
Pick the range (if one port, eg 20000 to 20000)
Select both protocol
Enter the ipaddress of your computer (find this by going to Run -> type 'cmd' and press enter -> type 'ipconfig' and press enter ->then you should see your ip starting 192.168.1.???
Enter this address into the Linksys page and then press 'Save' at the bottom.
Port should now be open.
NB - If its to be used with Azureus, this article may help:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Azureus.htm
May 27, 2008 | Linksys Wireless-G Broadband Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
