Question about Vacuums
I have a Fantom Fury and need to replace the belt. Please tell me how to get into it so the belt can be replaced. It is a Fantom Fury Vacuum Cleaner # 3680093 Fantom Technologies Model # F10051 01
reddevil6
  • 1673 Answers
SOURCE: fantom fury vacuums
Most power heads have some screws from the bottom to take out, the the top comes off, then you can get to the belt.
Posted on Feb 14, 2008
defrankond
  • 65 Answers
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
Vac Belts
  • 701 Answers
SOURCE: Where can I find a belt for my Fantom Fury vacuum
You can get replacement belts and view the manual here:
Fantom Fury Replacement Belts and Manual
Posted on Nov 28, 2009
Testimonial: "Thank you! Very helpful and speedy response."
  • 159 Answers
SOURCE: My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
Posted on May 10, 2010
joeguest2
  • 2080 Answers
SOURCE: Is my vacuum FM310K considered
Here is a link to the parts available for your model of vacuum:
http://www.appliancefactoryparts.com/vacuumcleaners/brands/fantom/fm310k.html
And here is the link to the belt that you need (part number XFB1310):
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=1043859&modelsID=137895&typeName=vacuum cleaner
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on Jun 13, 2011
Is my vacuum FM310K considered a Fantom Fury? I need a belt and can't figure out which one to buy!
Joe.
Jun 13, 2011 | Vacuums
May 01, 2010 | Fantom Vacums XT450K Upright Vacuum
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Change my belt on a fantom vacuum model number is f1420gf
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766591
Generic problem for all Vacuums
Change my belt on a
Posted by sylvester021 on Jul 10, 2008
Change my belt on a Fantom vacuum model number is f1420gf
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt change on the Fantom is to remove the bottom plate by undoing the screws, clips or levers, then cut off the old belt, remove the brushroll on the pulley side and place the new belt on the pulley side and replace the brushroll. Then use a belt puller or screwdriver with a hook on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line. The replace the bottom plate and you should be fine. The recommended belt change on a vacuum with a flat belt is every 4 to 6 months for the best cleaning and always use the genuine belts for the Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Fantom fury vacuum
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom fury vacuums
Feb 07, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
229 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
