Question about Philips Magnavox 51MP392H Rear Projection Television
I need power supply board - Philips Magnavox 51MP392H Rear Projection Television
  • 10,594 Answers
Your Philips 47PFL7864H/12 is UK model and it is multicolor system. (PAL, SECAM, NTSC)
Its power supply board wont be available in US.
THIS part store may help you to have required power supply board.
Click on above link to see power supply board that looks similar to your required board.
Or call Philips UK Parts to get that power supply board.
Hope this info will help you.
Thanks.
Posted on May 01, 2010
I have a Vizio E50-C1 Model #LTCWSKAR Power supply # (X)ADTVE2420AD4 Main Board #GXFCB02K009050X
You need to find out which board the led driver resides on. The main board sends a signal to the power supply board to turn on the LED's Look on the power supply board for swollen capacitors. They all have to have flat tops. If any are bulged, they have to be replaced www.shopjimmy.com. TV Parts Universal TV Stands DLP Chips ShopJimmy These guys can tell you which board you need.
Jul 28, 2017 | Vizio Televison & Video
Will not power on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Jun 06, 2012 | Televison & Video
Will not power up. Tested from plug to power board. Power does not leave power board from any terminals.
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
Nov 25, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Please hgelp
Power supply board is dead,the board that where the power a/c cord plug into it.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Tatung V20KQDX 20.1 in. LCD Television
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
I have an Intel D865GBF motherboard in my PC, which stopped working. I replaced the power supply because there was no power to the board. Now I have power, but when I hit the power button nothing happens.
The exact same thing happened to my D815EAA2. In my case an overheating power supply destroyed the board. Do the following:
1. Check the power supply you replaced it with works on another system.
2. If it still doesn't work with your board, the board will need to be replaced.
Nov 20, 2009 | Intel D865GBF Motherboard
No picture
The problem can be in the bcaklight inverter board or the main power supply is not supplying the power to the inverter board. The main power supply gets the turn on signal from the control/main board.
Nov 03, 2009 | LG 42LB1DRA 42 in. LCD Television
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Philips Magnavox 51MP392H Rear Projection Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
