Question about Logitech Z-5300 Computer Speakers
Headphone jack is weird...
My speakers are working just great, only that when i plug in my headphones into the provided jack from the volume control box, the headphone volume is extremely low, and doesnt send much bass, and also the sound coming through sounds like its one of those cheap streaming audio with the weird background noise
  • pnomaster Mar 28, 2008
    yeah their panasonic, their extremely good and ive never had any problems till i plugged them in. they worked perfectly on my other logitech X-530s, and the volume is fine on my computer, literally when i plug it in it all changes
  • 3 Answers
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Posted on Mar 27, 2008
  • TOMMYPIMPZ Mar 28, 2008
    ok i want you to try these steps than let me know ok.
    1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
    2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
    3. Ensure that the SoundTouch
    remote control is firmly connected to the back of the subwoofer.
    4.
    Connect the power cord from the subwoofer and connect it to another
    single power outlet in your house. If you have an automated voltage
    regulator (AVR), please connect the power cord through the AVR instead
    of connecting it directly to a power outlet in your house.
    5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
    6.
    Turn on the Matrix Mode ON. This option is on the SoundTouch remote
    control. This is to ensure all speakers from the speaker system will
    produce audio that will be played from the audio device.
    7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio
    device.
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
Ok so 1 of my kidos has the RCA 20F420T tv, and i guess there is no headphone jack hole, so i went and bought adapter that plugs into the av jacks, still doesnt work can you please help!!!
Without knowing the specifics on this adapter - I can provide only provide some clues as to how this works.
Basically, the A/V jacks on a TV has a "fixed" audio output level - this means that the sound levels on the A/V jacks is NOT controlled by the volume control of the TV itself. You should be able to set the TV volume to minimum and then use the adapter's volume control to make the earphone / headphone sound louder and softer. Your TV however, may have a setting in the menu that can change the audio from "fixed" to "variable". If set to "variable", when turning the volume down for the TV's built in speakers will also turn the volume down on the A/V jacks as well. You do not want this to work like that as the sound in the headphones and the TV speakers will be same - instead of the TV speakers being off and the headphones on.
I hope this helps and good luck! Please rate my reply. Thanks!
May 26, 2011 | RCA 20F420T 20" TV
Initially the main speakers would not shut off when the headphones were plugged into the headphone jack. I reset the audio settings to the factory default. Now the headphone jack does not work. How do I...
If you right hand mouse click on the louspeaker icon, click on open volume mixer.
You can set the headphone volume and speaker volumes from there. (depending on your OS and set up preferences)
Nov 17, 2010 | Toshiba Tecra 8100 Notebook
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Headphone volume?
Unfortunately, I believe this is by design. The knob does not control the volume of the headphone jack on those speakers. The best you can do is set the volume control in Windows so that the headphone volume is acceptable and turn the knob up higher for speaker listening.
Mar 07, 2008 | Logitech X-530 Computer Speakers
Problem in audio drivers in pc
I'll need more info on this problem: what type of connection do the headphones use? USB? Bluetooth? Classic audio jack?
Solution bellow applies in case of "ordinary" audio jack headphones. Also, check if your headphones have a built-in volume control (usually located on the cable). If that is the case, look for a Microphone On/Off switch if one exists.
Step 1.
Make sure that you've plugged in your headphones in the correct jack. These days, they are usually color-coded so Microphone should go be plugged into a red jack.
Step 2. Run "Volume control ["Start > All Programs > Accessories > Entertainment >Volume Control"] or double click the speaker icon in your System Tray if it's present.
Step 3. In Volume Control, activate "Options > Properties". Find "Microphone" and "Line In" under the "Show the following volume controls:" and activate them. Click ok.
Step 4. Maximize the volume on the "Microphone" and "Line In" slider.
Hope it helps. Rate me. Thanks.
Feb 17, 2008 | Audio Players & Recorders
Connection to Laptop
Since the majority of laptops do not have multiple sound outputs you will need to buy a couple of headphone splitters. Plug the first Y splitter into the laptop headphone port and plug one of the input cables going to the speakers in one arm of the Y. Next, plug another Y splitter in the remaining arm of the first Y. This will provide you with the other two inputs that you need. Plug the remaining speaker cables into the other Y arms. From there it is simply controlling the speakers using the laptop volume and/or the speakers volume. You will not have fader control on a 3.1 or 5.1 speaker system but it will give you what you are looking for. I have this same configuration at my office using an IBM laptop and a 5.1 surround sound system. Good luck. JC
Jul 29, 2006 | Compaq PS330 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
390 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
