Question about Maytag MGR5875QDS Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
I have a error code of 596 6ATH and cant seen to
I have a Maytag gas range MGR5875QD and I have a error code of 596 6ATH and cant seen to reset what causes this and what do I need to do to reset it?
  • 5,911 Answers
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question uder is correct, the instructions for Sabbath mode are listed on page 14 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
Posted on May 01, 2010
Testimonial: "I was able to reset by holding in the clock button for about 5 seconds and it all went back to normal. Thanks"
Oven sets off co detector
Then the gas is not burning correctly, the problem can be any number of things, but please have it checked right away, CO is a killer, and you just pass out never to wake up, happened to a friend.
Feb 02, 2012 | Maytag MGR5875QD CleanDesign Gas Kitchen...
My oven burns with a yellow/orange flame How do I adjust it to burn with a blue flame
Sound like the igniter is not reaching the correct amp draw, so it is not opening the gas valve all the way. Watch this video on troubleshooting a gas oven. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Maytag MGR5875QD CleanDesign Gas Kitchen...
STOVE CODE FLASHING
f9 depicts a door lock error
3 specifies the latch lock lower sensor
Mar 01, 2009 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven does not work
most common cause of gas range, oven not heating is a result of a faulty oven ignitor, you would need to verify power(110volts) to ignitor, located under iven floor attached to the bake burner. simple enough job for the homeowner to replace probalby about 50-75 for part
Oct 07, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
REmove bottom of oven
that is not the right model number should have 11 char usually mrg5870aaq ,
take all the racks out slide two tabs in the back forward grip on the side lift out. on some units you may need to take the back fan cover off
May 15, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Maytag MGR5875QDS Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
195 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
