Question about Quantaray QSX-DigiPro 8500 Tripod
Quick release plate with 3/8 inch screw
Does this exist?
Try looking at your Local Photoshop. I have always had good luck at Wolf Camra. Try there website.Or Creve Cour Camra as well.
Posted on Jun 06, 2008
Need to replace the ravelli quick release plate for ballhead tripod
Here is the complete unit replacement:
http://www.amazon.com/Ravelli-Professional-65-inch-Carbon-Release/dp/B004RCHX0W
No parts lists are available on line for this tripod.
Jan 14, 2013 | Ravelli Professional 65" Ball Head Camera...
Giottos MT-8170 center top plate 3/8" screw broken, can the screw or plate be replaced?
You unfortunately can replace the screw; however you can find a new plate at www.tripodquickrelease.com. They carry Giotto quick releases.
Dec 25, 2012 | Giottos Photography
DONT KNOW HOW CAMERA GOES ON TRIPOD WILL ANY CAMERA WORK ON IT OR DOES JUST CERTAIN ONES WORK ON IT IT IS A DYNEX 60 " DIGITAL TRIPOD
It is usually obvious where the camera goes, so I am pretty sure that what you have is a tripod with a quick release plate that doesn't have the quick release plate fitted. This is very common when you buy a tripod second-hand. The quick release plates get attached to a camera and people forget to reunite them with the tripod before disposing of it.
If you bought the tripod new, then look in the packaging for a plate with a screw to attach to the normal camera tripod screw in socket. There ought to be more than one. The screw is standard throughout the world, except maybe Germany that used to use a different size. Any camera you have will have this socket on the bottom, a threaded hole about a quarter inch (5 or 6mm) in diameter. The plate will be a design peculiar to this make of tripod, and if you lose it or don't have it you will be unlikely to get another.
Jan 25, 2011 | Dynex 60" Universal Tripod
I cannot figure out how to get the plate off the head. I end up either putting camera on, then twisting the whole thing onto the tripod, or putting the head on the tripod and twisting the camera around to...
Sounds as if you haven't unlocked the quick disconnect plate from the 222 head.
Release the quick disconnect plate from the 222 pistol grip with the thumb release it will click open and pop the release plate up a bit to remove it. The affix this plate to the camera tripod socket 1/4 x20 female thread on the camera bottom. The underside of the quick release plate has a "D" ring to screw it to the camera, fold over the "D" ring and when you pit it back on the 222 set the edge under the lip and set it down the brass pin then will snap the thumb release over and lock into place.
See my diagrams
And the release plate
Jan 22, 2011 | Manfrotto 222 GripAction Ball Joystick...
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
I have a Samigon BSA 650 tripod with a missing quick release plat
Try http://www.tripodquickrelease.com/Generic_Tripods.htm for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Nov 10, 2009 | Photography
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Missing tripod quick release plate for AMBICO v-0552
You can purchase on amazon, take a look here: Ambico 54 Inch Tripod with Quick Release 0555. I hope this was helpful. Cheers
Jan 01, 2009 | AmbiCom V0552 Tripod
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Quantaray QSX-DigiPro 8500 Tripod Logo
128 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
jd83854
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
