Question about Hayward SAND FILTER, PRO SERIES
MY PUMP ISNT RUNNING WELL N SAND SHOOTS OUT. WONDERING IF THERE ARE FILTERS INSIDE PUMP THAT MAY ND CLEAN
    Sergeant:
    Champion:
  • 333 Answers
The sand is the filter.Un-screw the top of the unit and clean out all the sand and replace with new sand. This probably should be done every two to three years. Use silica sand. Home depot
Posted on May 02, 2010
Is there a filter on Samsung washer model WF337AAL/XAA
should b were the pump connects to or up inside the hose from mech to pump
Feb 19, 2015 | Samsung Washing Machines
Why is sand shooting back into pool
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 07, 2011 | Waterway 22" Swimming Pool Sand Filter W15...
I have a Dreamline sand filter by hayward... it is shooting all debris dright back into pool. It works to put it on waste but not the filter function. Also, if we backwash it is still clean. i havent had...
If the pool filter is blowing sand and debris back into the pool, it is most likely due to backpressure. This is cause by air in the lines. You most likely have a crack somewhere in your system. Start by checking all of your connections and plumbing with your filter and pump. Then start checking your pipes, etc.
Jul 25, 2011 | Hayward SAND FILTER, PRO SERIES
Hayward 1.5 hp sand filter
Hi i have a Hayward S-180 sand filter and when i clean the pool green algie shoots back into the pool.
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
Water not pushing out hard
it may need fresh sand in the filter or back flushing? it could also be the pump motor getting claped out
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Back - siphoning when the pump turns off.
Make sure you dont put too much sand it will come back out.Put the correct amount and bump the pump correctly.
Jul 23, 2009 | Water Pik Flow Valve Assy. Series II...
Intex Easy Set 530 Gallon Swimming Pool Filter Pump does this keep your pool clean when running all the time?
No, the filters/pumps are much to weak. Not only is that filter too small for the pool but it is a cartridge filter which is the cheapest form of filtration. I hate to break it to you but a good pump/motor/filter is going to cost you around $600-$800.
Jul 05, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
My pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
May 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Apr 25, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
105 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
