Question about Garden
WHAT SPARK PLUG SHOULD I USE IN MY OLD HOMELITE CHAIN SAW UT 10045A??
    President:
  • 2,220 Answers
Champion CJ6 according to your IPL.
Find "SXLAO Chain Saw UT-10045-A" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
Testimonial: "thank you ill give it a try"
I need a manual for Homelite Texron #105064
I found this download link for the Homelite chainsaw ut10506-4 parts manual, if it is helpful.
http://megaslides.com/doc/9405595/homelite-chain-saw-parts-manual-for-xl-chain-saw-ut-10506...
No operators manual found.
May 02, 2017 | Homelite Garden
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
No spark on my homelite 150 automatic chain saw
remove the cover then the small wire from the coil crank it over if you get spark the wiring or switch is bad if still no spark the coil is bad
Aug 28, 2012 | Homelite Garden
Spark plug gap for homelite textron ut 10080c chain saw
Hi idone8...
Set your gap using a round feeler gauge to .28 to .32
Please take time to rate me
Sep 08, 2011 | Garden
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Lou
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
No spark superxl ut-10045-c
The following are givens:
1. You replaced the spark plug with a known good one and the malfunction persisted.
2. You did something similar to the following in an attempt to isolate defective parts and you concluded the ignition is not producing spark.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
I found your saw "SXLO Chain Saw UT-10045-C" by following the instructions here:
Both the solid state ignition and condenser (most likely failures, but no promises) are NLA at the authorized site, part numbers are still valid. An Internet search for "Homelite YourPartNumber" displays many sources other than eBay.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 03, 2010 | Homelite Garden
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
