Question about Mongoose 20-Inch Gravity Games BMX Freestyle Bike
The handle bars turn separate from the tire, how do i tighten
    Sniper:
  • 58 Answers
Hi, get them straight, then tighten the one in the middle nearest to you on the stem, it's called when you are sat on the bike, also there could be a 2 bolts on the side of them stem... let me know...
mark
Posted on May 03, 2010
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
The front of my bike wobbles at low speeds and in sharp corners like parking lots.2007 Electra Guild Classic
if the wheels not buckled it sounds like wheel bearings. lock the handlebars and see if there is movement to front wheel, left to right.
Mar 20, 2013 | Motorcycles
I Have a shimmy in front fork when I hit a bump, what do you think
Hi, Ed and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Front End Wobble
http://www.johndee.com/vbulletin/archive/index.php/t-8715.html
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Apr 21, 2012 | 2005 Yamaha Royal Star Venture
The front tire and the handle bar are not turning together. When I turn left or right the handlebar is all that moves. The front tire is just kind of "there". How do i get the two connected so...
Depending on how old your bike is there is an allen head or a nut at the top of your handlebar that when adjusted properly tightens the stem of the handle bar. You just have to tighten it down. Most use metric allen wrenches or sockets.
Mar 05, 2011 | Cycling
How do I put the handle bars and tighten them on the stem?
at the base of the middle bar there should be a thin bolt that you tighten with a 2 inch pipe wrench and holding onto the bars and tire with your knees so bars stay straight.
Dec 31, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
How do you raise the handle bars on a mongoose scorch bike?
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Nov 07, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How do i tighten the steering tube? the front wheel can turn left/right while the handle bars are straight ahead.
mcdevito75 here, There may be a bolt on top of the handle bars you can tighten, or a clamp just under the handle bars you can tighten, this clamp may also be on the shaft just above the wheel.
Jun 26, 2010 | Razor E300 Scooter
How do I attach the hadlebars?
the bars go throuhg the hole down into the front wheel. on the bar where the the neck goes into the frame there is a hole in that a long bolt goes in that, then the wedge shape nut goes on the long that runs down the neck into the frame that the front is in. make sure that the wedge bolt will line up with wedge on bar. place through frame into wheel so the neck bottem out get your ratach and start cranking as it get tight line up neck w/ tire and lock it down pull up to check turn head just in case
Feb 21, 2010 | Dynacraft Girls 16" Barbie Bike
My crank/chain is skipping on my mongoose pro bmx. This just started when I was riding it, and it skipped. The chain is in the right right place and does not seem to be skipping place, but the crank is...
It seems you will need more tension on the chain. Place the bike upside down, loosen the nuts, grab a broom stick or bar and place it between the rear tire and crank housing straight up and down with the handle bars away from you, push the bar away from you. When done properly the tire will come toward you tightening the slack in the chain. While you hold pressure on the bar tighten the nuts and WALLA.
Dec 04, 2009 | Cycling
How to replace tie rods and bushings in a 1997 dodge caravan
I recommend you get a Haynes or Chilton repair manual for most auto parts stores ($20-$30). But to save you some money:
Tie Rods:
1. Loosen the lug nuts.
2. Raise front of vehicle.
3, Support it with jack stands.
4. Chock/Block the rear tires.
5. Set the parking brake.
6. Remove the front tire.
7. Mark the nut shaped end of the tie rod and the jam nut with a straight line on top.
8. Using two wrenches - one on the tie rod (nut shaped) end and the other on the jam nut,..loosen SLIGHTLY the jam nut (clockwise turn). While loosening the jam nut - make sure you count the number of turns 1/4, 1/2, 1, 2 etc...
9. Using 11/32 Socket remove the tie-rod end to steering knuckle nut.
10. Use a tie rod end separator (fork) or ball joint separator (jaws) and separate the tie rod from the steering knuckle.
11. Before turning the tire rod off the steering arm: Count the number of turns coming off the arm using the mark you put on the tie rod nut shaped end.
Notice on the final turn off the arm what the mark position is. This wil be the position you start when screwing the new tie rod on.
12. Place the jam nut back just short of it's original position.
13. Screw the new tie rod back starting with that start position and with the same number of turns.
14. Connect the tie rod and steering knuckle.
15. Tighten the tie rod to steering knuckle nut to 40 ft-lbs.
16. The tie rod end and jam nut should then be tightened. They should be close anyway within a 1/8 turn.
17. Install lug nuts.
18. Lower Van.
19. Tighten lug nuts to 100 ft-lbs. Using the everyother nut until all are tightened process.
20. Wheel alignment? Test drive Van and have checked at an alignment shop.
The Stabilizer Bar Bushings:
Steps 1. thru Step 6 above. Remove both tires.
7. Remove bolts (should be 10 of them) attaching the cradle plate to the bottom of the front suspension cradle.
8. Remove the cradle plate.
9. Remove the stablizer bar links from the stabilzer bar. Confused? There is a straight bar coming from the Strut down to the sway (stabilizer) bar (which goes from one side of the Van to the other). Remove this nut.
10. Remove the stabilizer (sway) bar bushing retainers (one on each side) from the front suspension cradle.
11. Be careful this bar is heavy and will fall suddenly and may hit you on the head!!
12. Remove the bar and bushings as a unit (together).
13. Install the new bushings with the slits facing the rear of the Van and the square corners facing the ground.
14. Make sure you clean the areas on the bar where the bushings are positioned.
15. Use lubricant (non-petroleum based, like vegetable oil) to easy re-assembly.
16. Re-assembly is pretty much the reverse.
Hints:
a. Align the stabilizer bar in position using the depressions in the cradle.
b. Do not tighten all-the-way the bushing retainers until later.
c. Tighten stabilizer bar to link stabilzer (sway) bar to 65 ft-lbs.
d. Tighten bushing retainer nuts to 50 ft-lbs.
e. Tighten the cradle plate bolts:
M14 at 123 ft-lbs
M12 at 80 ft-lbs.
Let mne know if this worked for you. Good Luck!!
Any other questions? Drop me a line on fixya.com!
Nov 21, 2009 | 2000 Dodge Caravan
Mongoose 20-Inch Gravity Games BMX Freestyle Bike  Logo
108 people viewed this question
Top Mongoose Cycling Experts
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Roger Paull III
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
