Question about Dishwashers
Thermostat on zanussi zsf6150 dishwasher
My thermostat is faulty on my zanussi zsf6150 dishwasher but cannot locate it. where can i get a copy of the schematic diagram for it.
  • Anonymous Oct 19, 2008
    The machine completes the full cycle apart from not having any hot water!
    I have put a resistance meter across the heater,it is not open circuit.
    Any help please
  • 185 Answers
Its on the lower right hand side where the motor is there should be 2 wires going to it
Posted on Mar 25, 2008
Water in the base of the dishwasher cutting out the module- flashing indicating flood protection. Sound as though a seal has gone- 6 year old, can anyboby help?..
look for a blockage in a chamber on the left hand side (remove left panel for access. alternativley look for leak on the right hand side where a rising tube enters the cabinet to supply the top spray arm it has been known to break the threads and leak inside ( a new rising tube will be needed.
Nov 05, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
We have a Zanussi that has been fine for 2 years but the last week it has turned a powdery white inside and on the door with all the dishes becoming chalky. There is rinse aid and salt. Hope you can help
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Jul 15, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
Hi,ive replaced the heating element on my zsf6150s-no hot water
Try resoldering the main PCB connections, it cured my problem.
Jan 23, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
Zanussi zsf6150 water not heating
Hi. i would test the element first. this will be the likely issue.
First, open the door
and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
Sep 02, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
Wont heat up when put on to wash
Try a resolder of the main PCB connections, cured my hot water problems.
Jul 15, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
I have a zanussi zdf 501. After a few minutes it freezes at .20 on the display. I don't think up to that point the cycles (all) are running properly
I found that at 83 minutes my washer stopped. I found on examination that the powder dispenser had not opened, some granules had clogged the clip mechanism. I cleaned around it a bit and the next cycle the machine went right through. I checked, and this time the powder dispenser had opened. Hope this helps
May 25, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
Dishwasher not heating up
I found that resoldering the main PCB cured a dry joint and all is hot again
Apr 06, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
Heater not working
Try resoldering the main PCB connections, that cured my problem
Nov 22, 2008 | Zanussi 24 in. ZSF6150 Free-standing...
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Zanussi Dishwashers
Water is not heating
you will have to ohm out the element if you have no continuityyou will have to replace it
Mar 25, 2008 | Zanussi 24 in. ZSF6150 Free-standing...
Dishwashers Logo
358 people viewed this question
Top Dishwashers Experts
