Question about GE DCVH515EFWW Electric Dryer
The dryer takes a long time to dry the clothes, it appears as though the vent isn't working properly. Could the vent tube to the outside of the house be too small in diameter?
    New Friend:
  • 107 Answers
The vent should be 4" in diameter. It may need to be cleaned and your dryer may need to be cleaned.
Posted on May 01, 2010
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Does not Dry. Appears to have low air flow.
most of the problems associated with this problem are caused by lint being in vent tube to outside and restricting the air flow. clean out vent tube, from dryer to outside. this should help. repost if need be. good-day ! if you have too. clean out bottom of drier with a vacuum. around the fan and where theres lint trapped.
Jan 24, 2012 | Whirlpool WGD7300XW Dryer
The dryer is hot but clothes isn't dry.
plugged vent to out doors, either the vent louver outside, the tube is clogged, or the dryer itself nreeds to be talken apart an vacuumed out.... main source of fatal dryer FIRES, and house fires is a clogged vent tube / exhaust.
Nov 19, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
Since a month ago our dryer takes a long time to finish a load, A load which used to take 45 minutes to finish now takes close to 2 hours to finish.
check all of your duct work clean it out make sure there is no lint in the duct work going from the dryer to the wall also check the duct work going from the wall to the outside of the house
Dec 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
My fisher paykel dryer does not dry properly. I have to run 2 cylces to make the clothes dry
If you have to run the dryer 2 to 3 times as long to dry the clothes then you just need to make sure the vent hose behind the dryer isn't kinked up and the vent is open all the way out side ,,, that will fix it for you.
Larry
Nov 25, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
GE DCVH515EFWW Electric Dryer Logo
101 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
