Question about Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor
Bought a new pressure switch for the ridgid twin stack it will build up pressure and cut off normally but when using air tool it will just keep losing pressure until zero even though unit comes on and tries to build pressure if i quit using the air tool it will build back up normally and cut off. help me?
  • 349 Answers
You have to have a leak some where other than you compresser. check the lines and fitting s to you air tools.
Posted on May 05, 2010
Compressor stops before building pressure
I would bypass the thermal safety and test the unit. Does it go to proper pressure? run it through two cycles. If it looks good, reconnect the temp sensor and use it until a new one can be obtained.
Sep 02, 2014 | Hitachi EC119SA Twin-Stack Air Compressor...
Hitachi ec89 will not shut off
IF it is building up to the correct pressure then the pressure switch has malfunctioned. The part number for a new switch is 160580.
Parts and owners manuals are located at this link near the bottom of the page;
Hitachi EC89
Aug 19, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Pressure release keeps kicking off
The pressure switch is faulty needs to be calibrated.
Jun 22, 2012 | Ridgid 17048 Gas Powered Wheelbarrow Air...
MY TWIN STACK YELLOW EXTREME DUTY COMPRESSOR LEAKS AIR FROM PRESSURE SWITCH? WHAT SHOULD I DO?
Hi, my name is John. Welcome to FixYa. You will have to replace the pressure switch. Thanks for choosing FixYa...John
Nov 19, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Why does my compreeor switch release the air after reaching the required pressure instead of holding the air at the required pressure??? I've just purchased and fitted a new automatic cut off switch to my...
There are two valves in play here. There is a relief valve that opens when the motor kicks off to release the pressure in the compressor itself. That is normal, and is required so that the motor can restart next time without having to overcome that pressure. The other valve is the problem. It is a reed valve between the compressor and the tank. This valve's job is to prevent the air in the tank from returning to the compressor. Think of it as a ratchet for the air. It is this reed valve that has failed.
May 27, 2010 | Northern Industrial 2 Hp Twin Tank...
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Which air compressor is better-the rigid twin tank or the emglo twin take?
I think Ridgid has now lifetime warranties. You have to fill out papers and mail them. I have a few Ridgid tools and I love them. So check out the Ridgid, you can't go wrong.
Mar 16, 2010 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
The compressor fills up with air fine.AS i start
I would check the pressure switch. It probably has bad contacts in it. You could try to clean the contacts first before replacing the unit.
Nov 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Have rigid twin stack air compressor. Only keeps about 75 psi and keeps running. I do hear air from the exhaust port (seems normal). Haven't used it for a while. Any ideas? Thanks, in advance.
possiably the " reed valves under the head are not closeing off all the way. These may be bent or somehow distorted their tension most of the time from exsesive heat. Good luck
May 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Ridgid air compressor OF45150A twin stack
sounds to me like u do not have it on a big enough circuit, look on the name plate for FLA, this is the amps it pulls to start up, and size ur circuit for that amount.
Dec 28, 2008 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Logo
393 people viewed this question
Top Ridgid Hammering Experts
Tim Whalen
Hippy_dd
Are you a Ridgid Hammering Expert? Answer questions, earn points and help others
