Question about Estate TEDS740JQ Electric Dryer
Estate Dryer Model TEDS680EQ1
My estate electric dryer has been working fine until yesterday
March 24, 2008 when it stopped during a normal drting cycle.
The air was hot when it stopped.
I have checked the following :
All controls
door switch
timer
fabric/ temperature slector
start/ end of cycle button
Today removed back panel from controls and checked all connections.
All good. Removed back panel from dryer checked thermostate and heater box connections, all good.
Removed top of dryer and front panel and checked connections and belt,
all seemed to be in good working order.
Drum turns freely. Did not check actual motor other than turning of the drum.
Please make suggestions before we go purchase a new dryer.
Thank you for your help
JJ
  • 185 Answers
Check the thermostats and see if your belt is still there if not put a new belt in
Posted on Mar 25, 2008
  • william ludolph Mar 31, 2008
    check the overload in the motor and see if you have continuity
Estate dryer modle TEDS680EQ1 turns on but wont get hot
Check all the thermostats for continuity.
Dec 01, 2012 | Whirlpool Dryers
Dryer stop working has power going to all parts
Check the continuity of the thermal fuse, often the culprit. Also check the power relay. Sorry but I am not familiar with the Estate dryers. But the above are two common problems in a wide variety of electric dryers.
Nov 10, 2011 | Estate EED4300TQ Electric Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
Nov 11, 2008 | Estate TEDX640JQ Electric Dryer
Estate teds680eq1
hi thanks for the question i would check the thermal fuse located at the back of the dryer remove back panel you will see on the air duct a small piece with one screw holding it on 2 blue wires going to it replace this part but also vacuum the venting and the rest of the dryer as this fuse will fail again if venting is not right thanks the appliance doc
Sep 22, 2008 | Estate TEDS740JQ Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
238 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
