Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Spits, sputters and blows black smoke at higher rpms
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# 446777
Idles at low rpm but bogs down to a fluctuating idle, spits, sputters and blows black smoke at higher rpms
or if you engage the blades. Must play with tension on governor or disconnect then reconnect the fuel solenoid to smooth out idle. Carb is completely rebuilt with new fuel filter. This problem happened suddenly. Not gradually. (Solenoid does engage and disengage when key is turned on and off)
5 Suggested Answers
  • 376 Answers
SOURCE: husqvarna 130 governor
The governor is there for a reason, to keep the engine from over-reving and self destructing. Sure, you can get more speed by removing/raising the rpm's, if you want your rod to end up sticking out through the back of the engine case.
Posted on May 22, 2009
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
mowerman1857
  • 389 Answers
SOURCE: need valve clearance for 26 hp b&s vtwin
.004 to .006 on both intake and exhaust
Posted on Sep 19, 2009
Keep blowing fuse
fuse blowing is a result of excessive current draw from a dead short or failed electronic component
look for damaged wires or solenoids that are not working
Apr 18, 2016 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to check the charging system on a husqvarna riding lawn mower
check the battery voltage with engine off. Start engine and see if voltage is higher then it was before starting mower. If it is higher then charging system is OK
Sep 27, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Sputtered, died. Will not start anymore
Sounds like the carburetor needs cleaned and maybe rebuilt. If you can spray a little starting fluid (or a little carb. cleaner or anything volitile) into it and it starts and dies, you know it is in the carburetor.
I hope this helps.
Jul 29, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Drive belt pattern
Go on the web to www.milacalawn.com/partsasp they have the factory diagrams for any parts you may need for your Husqvarna tractor and a belt diagram for the deck... Hope this helps.... ;-D
Jul 11, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
219 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
