Question about Kenmore Dishwashers
Kenmore Elite dishwasher cleans poorly, low water
Kenmore Elite 665.1312 dishwasher is not cleaning adequately. Soap residue often remains on dishes; soap not completely dissolved at dispenser (used manufacturers suggested amount and rinsing agent). Upon inspection during cycle, water levels are always about 1/2 inch below heater unit. Checked and cleaned filters. Checked flow at inlet value. Replaced inlet water value. Checked overfill float for obstructions. Water temperature about 130 F. Upon starting a cycle, water freely accumulates in basin over 45 sec period before pump engages.Water drains adequately. Problem has persisted for 8 months.
  • 32 Answers
SOURCE: Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Posted on Apr 07, 2008
  • 4 Answers
SOURCE: Kenmore dishwasher not cleaning
Growand:
There is a rubber tube which supplies water to the top spray arms. That is, If yours has top spray arms. This rubber tube has to make a connection when one slides the top rack back in. That tube will rot after a while, check it out.
If the soap is not being used up, reduce the amount of soap you are using and run the dishwasher empty with a pie plate sitting on the bottom rack with a cup of distilled (cheap) vinegar in it. Run it hot and long, recheck and redo if neccessary.
Posted on Jul 30, 2008
  • 63 Answers
SOURCE: dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
Posted on May 24, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore Elite dishwasher not cleaning well and
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Jun 04, 2009
  • 677 Answers
SOURCE: rinse agent won't dispense in Maytag dishwasher
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Mar 30, 2010
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The soap does not dispense entirely (the soap dispenser opens okay) The dishes have a soap film and at times food residue on them... It appears that not enough water is spraying on the dishes. Is there a...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | Kenmore 24 in. 17019 Built-in Dishwasher
I have a Kenmore built in dishwasher. Serial Number 15989990 Model 665. My dishes are not getting clean. Lots of residue on glasses on top rack and dishes streaked. Any ideas? We thought it might be the...
Dishwasher
How to Buy
heatman101
Asker
Mar 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher is leaving white residue on dishes, won't come off
Their are quite a few reasons for a dishwasher to have white residue on your dishes. I will list some steps to take and help you get your dishwasher working again.
1. Are you low on Rise Aid? Most dispenser have a 1-6 setting right under the cap. Make sure your set between 3-4 for the best results. This additive helps in cleaning and drying your dishes and most manuals will say its required for best results.
2. What type of detergent are you using? If you are using the dollar budget type product you will get very poor results. If you are using a name brand make sure it does not have rise aid already included. Too much rise aid could cause white residue as well.
3. Do you have hard water? Hard water can make it more difficult for your dishwasher to clean. Be sure to use a dishwasher cleaner such as Dishwasher Magic at least once a month. Your dishwasher does a great job at cleaning dishes but when it gets dirty it needs a little help.
Dec 06, 2010 | Kenmore Dishwashers
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
1. No water
2. Not enough water
5. Not enough soap
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Poor Cleaning and getting worse
A common cause of poor washing is improper loading—dishes block or impede the spray arms or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with washing, the problem may not be your dishwasher. Your home's water pressure may be too low, the water may be too hard, you may not be using the right amount of detergent, or the water temperature may not be hot enough
Apr 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
141 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
