Question about Maytag Neptune MDE5500AY Electric Dryer
A paddle inside drum is loose, need to open top of dryer
Need to open top of dryer
  • Maytag Master
  • 528 Answers
First take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
Posted on May 02, 2010
2 Suggested Answers
  • 75 Answers
SOURCE: one paddle on inside of
Hello
you will open it from the back.
Thanks
Posted on Jun 08, 2011
Dryer is "eating" clothes; how do we fix it?
I suggest you find someone to "get inside" the machine drum and find out what is damaging the clothes. I could not find the machine in "Sears Parts" to look at the drum. (They have pictures for most all US machines). I am not sure the drum might not need to be removed to repair it. There should be something there that is "snagging" the clothes and could be sanded down or smoothed somehow. If it has removable "paddles" to tumble the clothes, sometimes one could come loose and need tightening. I have seen heavy objects like large tennis shoes loosen a paddle.
Be blessed.
Jun 26, 2014 | Bosch Nexxt WTMC3321US Electric Dryer
Paddle came off inside dryer drum I need to open the top so I can put more screws in
remove 4 screws around the door perimeter,remove door,then the front panel will pull off towards you then remove 2 hex headed screws just under where the top and front covers meet,then you can raise the top to replace baffle/paddle screws
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles came off inside the dryer
Remove the top and front of the machine. (Look for up to two screws them pop the top.) Remove the drum (be careful of the belt) Reattach the paddle - it should be self evident once you have the drum out. You might need to add a screw of two. While it is apart, Id be changing the belt.
Reassemble
Your wife will love you forever.
Simple.
Oct 09, 2009 | Dryers
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Inside paddle fell off
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top.Rotate the drum around and reach inside the drum. Re-attach that baffle.
Apr 09, 2009 | Whirlpool LER5636P Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
165 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
