Question about Microwave Ovens
My LG refrigerator, LFC22760 just stopped working. I am hoping there may be something we can do to do some trouble shooting as it appears it will be days before we can get someone to look at it.
  • 5 more comments
  • lgrasmussen May 01, 2010
    We tried all of those and nothing worked.
    Any further thoughts?
    I tied everything you suggested and nothing worked.
    My LFD22860 suddenly died. I cleaned the coils, checked the electrical outlets, plugged and unplugged it. Nothing. Any thoughts?
  • lgrasmussen May 02, 2010
    I am still puzzled by the fact that the LG fridge just stopped, no warning, no signs that something was wrong. Just on one minute and off the next.
    There is absolutely nothing. The whole fridge just stopped and when we plug it in there are no noises or lights. Any thoughts?
    I tried what you suggested and it is as dead as a door nail.
    Thanks
    Thanks! We have someone coming on Tuesday.
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on May 02, 2010
  • Charles T Nevin
    Charles T Nevin May 02, 2010
    So you tested the compressor relay and it was good. Then you have a compressor problem where it has lost freon or just wore out. This is not a do it yourself job. It requires a qualified tech.
    President:
  • 1,619 Answers
I am not sure but normally the freon leaks out and requires a charge normally. If the freon charge is fine it may be the compressor failing. If you go to a auto store you may be able to pick up freon to charge the unit. The system to check pressure on high and low side is spendy but can be bought there also.
Posted on May 01, 2010
  • 713 Answers
Hi,follow the stepwise solution provided below to help you with the fixing of your refrigerator that stopped working;
STEP 1 Check the power by opening the refrigerator door and looking to see if the light is on. Listen for the hum of the motor as well. If there is no sign of life, make sure the power cord plug is in the power socket and finally check the circuit breaker.
STEP 2 Verify that the temperature controls are set at the correct temperature. Many freezers and refrigerators have controls that change easily from an accidental nudge. Make adjustments as needed and use a permanent marker to tag the desired setting for later reference. Repair controls that turn too easily by using tape to secure them in place.
STEP 3 Clean the coils with a long brush or vacuum to remove dust and pet hair build up. In order for the refrigerator or freezer to cool properly a great deal of air must flow through the coils constantly. Find the coils either behind the unit or at the bottom front in which case you must remove the kick plate below the door. Ensure that nothing has fallen behind the unit that could block the coils.
STEP 4 Evaluate whether the fan is running if your freezer or refrigerator has the coils in the bottom. Access the panel on the back of the unit and look for small pieces of paper, dust or other objects that may be keeping the fan from turning properly. Use a vacuum hose to clean out built up dust and dirt annually.
Thanks and take care
My lg fridge freezer has stopped freezing since yesterday, model number gwb207flqa. help all my food is defrosting. even the fridge side isnt cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 27, 2011 | Microwave Ovens
Fridge has suddenly stopped working
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 04, 2011 | Microwave Ovens
Door left open over night and now the refrigerator is not cooling
Refrigerator
heatman101
Feb 24, 2011 | Microwave Ovens
Red light on fridge frezzer an keeps beepin
Refrigerator
heatman101
Feb 03, 2011 | Microwave Ovens
The fridge is completely shut down
Refrigerator
heatman101
Frigidaire bfph33m4lm mini frig does not get cold. Help!
heatman101
Jan 07, 2011 | Microwave Ovens
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
Philips 83-363c Refridgerator
Refrigerator
heatman101
My freezer section doesn't freeze despite upper section ( fridge ) working fine - is it something that can be fixed?
heatman101
Nov 14, 2010 | Microwave Ovens
N refridgerator not cooling, compressor is warm
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 12, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
