Question about Cuisinart DLC-10S Pro Classic Food Processor
Cuisinart Food processor
I have a Classic Cuisinart food processor that is quite old. There is a small plastic insert that goes on the stem which is broken and I need to replace it. Any suggestions? Motor Shaft need to be replaced mine is cracked. I can't get the old one off. Or the new one on! Help any one!
  • Anonymous Nov 05, 2008
    the small white patch that starts the machine when turned on will not start machin whichis model cfp5A
  • Anonymous Nov 29, 2008
    I can't remove the bowl from the machine. The part at the back of the bowl slipped of bowl and I replaced it on the bowl and now it will no let me remove bowl.
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Posted on Jul 14, 2008
The stem on my food processor is broken. Help to remove old part
Hi-I have a DLC-7, it looks a lot like yours. On my machine the stem is removed by pulling straight up. It is held only by the friction of a knurled section of the shaft, no threads or other fasteners. You could grip it lightly sideways with a pliers or vise-grips and then use hammer head to tap upwards on the side of the pliers. Squeeze the shaft firmly enough to grip it adequately, but not so hard as to crush it.
May 07, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I have a very old cuisinart food processor. It stopped after I tried to make a dough in the mixer
If it is old enough you may have burnt up the motor. I don't know that the older FP's are designed for mixing dough.
Jan 23, 2010 | Cuisinart DLC-10S Pro Classic Food...
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Jan 03, 2009 | Cuisinart DLC-5 Food Processor
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
I can't get the blades on the processor. there is a holder that somehow snaps into the blades before they are put on the processor
The regular chopping blade requires a stem adapter. The other blades require the detachable stem. I would double-check the user manaul to get a visual on it. Cuisinart food processors are great, but they are also the hardest to assemble.
-Tha Mp3 Doctor
Jul 19, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Need manual for food processor
Found it at:
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Appears to be locked but won't turn on
ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
This is very much a temporary solution until we get a new food processor, obviously a different model.
Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
Install Cuisinart stem cover
I was able to replace my pieces thru Small I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-10S Pro Classic Food Processor Logo
333 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
