Question about Optoma PK102 Projector
I have a Optoma PK102 portable projector and I cannot play any power point presentation which is loaded onto the device - any advsie on what is going wrong
Ahoy there. I have the Aaxa P2 and they told me to convert all the powerpoint slides to jpg first and then use the onboard media player's slideshow feature. It works great. I don't know if the pk102 has the same features but I hope that helps. If not you might want to consider getting a different one.
Posted on May 04, 2010
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
License key where is it
Software for what? can you be more specific?
Tony
Feb 20, 2013 | Optoma PK102 Projector
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
I need to reset my projector. It is bazook after I disconnected it incorrectly from my MacBook. It now shows the grid and then it twinkles maddly and the gris reappears, and the whole sequence is...
hy , i have an optoma pk 102 projektor and i have a promblem i start the projektor , shows me the "optoma logo" and than it's starts flashing and restarting , and show again the optoma logo. i try to connect to the laptop and show me the extend monitor for 10 secounds and restarting again, how can i fix the problem,maybe i cand upgrade the firmware?.Thanks
Apr 26, 2011 | Optoma PK102 Projector
I can't seem to figure out how to get the information from my computer to the projector. How do I get the info from my pc to the projector
Mar 21, 2011 | Optoma PK102 Projector
I've had this Optoma PK102 for about year and am not able to get desired results! What cable do I need to connect my Optoma PK102 and Apple ITouch. I have 2 Problems. Problem 1- I am unable to view...
Welcome to Fixya. You need to put the file on the projector for you to view the PPT presentation.
You need to connect a USB cable shown on the image below. If you don't have the cable i suggest you purchase on just bring the projector to a store to have a compatible usb cable.
Use the link below for the manual and more info about the product.
Manual
Specification
Thanks for using Fixya
Mar 13, 2011 | Optoma Office Equipment & Supplies
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
Projector can't connect to laptop
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
Feb 19, 2009 | Office Equipment & Supplies
Optoma PK102 Projector Logo
228 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
