Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Forgot password Have a GT704WG wireless modem/router. Forgot password for networking. Is there a way to find original password.
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Posted on May 02, 2010
Forgot password what to do
If you forgot the password to your network, simply give your internet service provider a call. They should have a 24 hour hotline for situations like this.
Jan 24, 2011 | Actiontec GT704WG Wireless Router...
I have Actiontec gt704wg wireless and am trying to set up my nook. It asks for a password and i dont know it
In order to get the wifi WEP key for your network, turn over the bottom of the modem- the default WEP key is on a sticker-
Bar that, on your pc open up a web browser, type in 192.168.1.1 in the address bar- by default the user name and password are admin and password- go to the wireless tab, and basic security settings- the WEP key would be listed there
Jan 08, 2011 | Actiontec GT704WG Wireless Router...
I upgraded the hard drive ram and OS on a 3 year old macbook core 2 duo. Now it won't connect to my wireless network. It will connect to wireless network at the local coffee shop. I have tried rebooting...
All you need to correct is entering in the WEP key for the wireless network- you will connect, but will be unable to browse wirelessly otherwise. The WEP key is found on the bottom of the actiontec- unless you changed it to something else- at which point you would need to log into the modem to find out your WEP key.(192.168.1.1 on a working computer in internet explorer/safari/firefox, un/pw admin, password or admin, admin; wireless settings)
Aug 15, 2010 | Actiontec GT704WG Wireless Router...
Forgot admin password
The only way to resolve a lockout is to restore the modem to factory defaults. This will require you to re-establish your DSL credentials, using the packet you originally received from your telecommunications provider.
The reset button is located on the rear of the unit. Depress and hold it for approximately 15 seconds. The reset process will start about 10 seconds after the switch is released.
May 16, 2010 | Actiontec GT704WG Wireless Router...
Anyone know default password for actiontec gt704wg dsl modem
The default settings are:
Username: admin
Password: password
May 14, 2009 | Actiontec GT704WG Wireless Router...
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Wireless is not enabled
open its program and check to see if it in AP mode, make sure it is in AP mode and the radio is turned on, clear any radio off button. go to the configuration and set up a wireless network, try first with a secureless network,
then when everything works, go for a WPA secure connection
Mar 24, 2009 | Actiontec GT704WG Wireless Router...
User name and password
Username: "admin" and Password:"password", unless you changed it. If you did, just reset the modem to the factory settings by keeping the reset button pressed, and admin and password should work again.
Dec 01, 2008 | Actiontec GT704WG Wireless Router...
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Cannot connect to admin on GT704WG
try power off/on and then reset hold the reset in for at least 10sec - holding it in for 1-2sec is the same as power off - but i would still physically remove the power for at least 30secs remove all the lan cables - just plug in the one PC you use then hold the reset for 10secs 192.168.0.1 - is the default login - so should work now - if not the router is faulty whats the status of all the lights on the router
Apr 13, 2007 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
229 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
