Question about Sony Mavica MVC-CD400 Digital Camera
E : 61: 00 my sony camera i currently fell down and won`t fous at all , the camera display this mesages . E : 61 :00 tthank you in advance
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 01, 2010
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a Sony DSC-W50 Cybershot camera that won't take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing more.
I have a Sony DSC-W50 Cybershot camera that won\'t take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing displayed
Mar 07, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Dsc-s2100
You might want to send your camera to your Sony Authourized Dealer for some technical repair. Since it accidentally fell, there might be a part from your camera that is affected by the sudden hit causing your lense to jammed.
Thank you.
Aug 01, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Camera FELL AND WON
the part which comes out when the power is on might have got stuck .. try repairing it .
Apr 09, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My phone fell down in water. phone restricted
your phone is liquid damage so refresh your software by the help of internal data cable
Oct 08, 2009 | Cell Phones
MY CAMERA DISPLAY ER MESAGE YHAT COMUNICATION
Purchase a can of compressed air from Home Depot, Lowes, or your local hardware store. Read the directions on the can first and then hit your lens with the air while rotating the camera. You probably have a particle of dirt or dust caught in the lens area.
Good Luck,
Eric
Jul 09, 2009 | Canon Cameras
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
K510i Sony ericcsson problem with display
IN ur sonyericsson phone there is prblm of motherboard plz contact sonyericsson center 1800-11-1800(toll free) no. ask about ur prblm.TTHANK U THIS IS DEVAL
Dec 04, 2008 | Sony Ericsson K510i Cellular Phone
Sony 200i fell down and now its display is not working properly.
THIS TYPE PROBLEM IS A EASY CASE THE LCD THAT U SAID IS NOT WOKING WELL REMOVE IT AND PUT ANOTHER ONE.
Nov 17, 2008 | Sony Ericsson W200i Cellular Phone
Sony Mavica MVC-CD400 Digital Camera Logo
115 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
