Start machine, fills with water and timer starts to run down but nothing happens
  • egabucci May 01, 2010
    is there any tests that i can do to determine exactly
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the issue is with the Timer going bad which is not starting the cycle, also if the Timer seems to be working fine then please check the Lid Switch. Please do accept the solution if the issue is resolved or post a comment with the manufacturers name and model no# for further assistance.
Thanks
Rylee
Posted on May 01, 2010
  • Rylee Smith
    Rylee Smith May 01, 2010
    Please post a comment with the manufacturers name and model no# for further assistance.
    Thanks
    Rylee
Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
have a technician check it out as it may be a board problem
normally the fill level switch ,when the set water level is reached activates 2 things
it stops the water in and at the same time moves the program on to start the wash cycle
so it is either that switch or the program board
Aug 13, 2015 | Bosch Washing Machines
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
When starting a cycle, tub will fill properly, then when it is time for the wash cycle to begin, nothing happens. you can only hear a relay or other type switch click one time. after the one click, the...
The question is why the main motor is not running. Either there is an open contact in the timer, or the motor has a blown thermal protector or tripped internal breaker.
Troubleshooting starts at the timer. Most washing machines have a wiring diagram on a sheet of paper either folded up and stored inside the control panel or pasted on the back panel of the machine. Find the wires going from the timer to the motor. The motor has two windings, RUN and START. The RUN winding has one connection to neutral (WHT or WHT/BLK, meaning white or white with a black stripe) and the other to the timer. The START winding has both connections going to the timer. The timer connects it power one way for agitate and the other way for spin. (The direction of current through the START winding determines whether the motor will turn clockwise or counterclockwise.)
If you are comfortable working in a live 120 VAC circuit with a voltmeter, use the wire colors in the diagram to identify the motor terminals on the timer, set the timer to the agitate position (i. e., right after the machine is done filling and you hear the click), then check for voltage on the RUN and the START winding terminals. For the START winding, measure between the terminals going to the START.
If you don't want to probe a live circuit, you can use an ohmmeter to test for continuity between the hot terminal of the power cord and the motor terminals on the timer. Repeat for the neutral terminal. A failure at this point indicates either a timer problem or (unlikely since the timer runs) a bad contact on the water level switch.
If you get voltage to the motor on both windings, or you have continuity through the timer for both windings, then, with the machine unplugged, test for continuity through each motor winding at the timer. An open indicates a problem with the motor. Note: most machines use a capacitor in series with the START winding. In that case, measure continuity between the capacitor terminal going to the motor and the timer terminal going directly to the motor.
Apr 17, 2011 | Washing Machines
Washer filled with water but will not start the cycle
Sounds like you have a bad timer, not too hard to fix. Just get yourself to an appliance parts store and give them the model of your machine and tell em that you want a timer. They should be knowledgeable on how to install it but if not its a pretty simple task. Just unscrew the control panel from in back so that it can flip up. Then pull the knob off the front of the timer and unscrew it. Next move over the wires one at a time being careful to put them on the same prongs as on the original one. Then screw the new timer in place being sure that its going in the same way the old one came out. Then screw it in, put the knob back on, screw down the control panel and you should be good to go.
Dec 12, 2009 | Washing Machines
The timer works and fills with water. the belt is
So you start the easher it fills with water but does nothing else is that correct? If so It is possible that your door switch is faulty
Sep 08, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Timer programme
Drain pump may be obstructed or defective. You may have to call your engineer back. Maybe he disrupted something.
Nov 13, 2017 | AEG Lavamat 72640 Front Load Washer
Open Questions:
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
