Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Noisy pump in bosch nexxt 500 washer
Is the pump in the bosch nexxt 500 washer noisy? mine sounds like a chugging train.
  • 1,998 Answers
No its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
Posted on May 01, 2010
I have a Bosch Nexxt 500 front load washer that will not drain when it gets to the spin cycle. The drain pump is clear and free from obstructions as well as the lines are clear and manually filling up
Sounds as if the rinse hold button has been set by accident.check the switches top left.if they are correct, then next query would be logic board has a problem, sometimes fixed by hair drying the board in cases of damp lack of use washer.if machine completes most cycle then I suspect rinse hold button is on or open circuit.
May 12, 2014 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Noisy pump on bosch 300 series washer
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Aug 19, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Nexxt Washer Problem
timer not sending signal, or bad transmission
May 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
321 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
