Question about Hayward SAND FILTER, PRO SERIES
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a new one. The sand filter sticker came off, so I don't know what model the sand filter is, but the lateral assembly has a part number S200F, which I can't find. The lateral assembly from the bottom of the base to the top of the center pipe is 18" in height. Can you tell me which lateral assembly to buy?
    Top Expert:
  • Hayward Master
  • 8,686 Answers
Or if you can add a coupler to pipe raise to good edge to insert into multiport
Posted on Apr 06, 2018
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
If you want to purchase new hayward pool filter parts then go ahead to uncover the benefits of using Hayward pool filters. To ensure regular cleaning and sanitizing, installing a good quality filters and pumps is the right solution.
Why wait then? Buy the Hayward pool today from a reliable store. You can buy it online where you can get genuine devices at the best price possible.
https://www.allpoolfilters4less.com/haywardpoolfilters
Posted on Mar 05, 2018
  • 640 Answers
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Sep 02, 2010
Can a Hayward s 166 t Hi rate sand filter be rebuilt
Parts can be replaced sure, but will it be worth it compared to buying a replacement or even upgrading. Laterals (if broken sand gets in pool) can be replaced on this unit from 48 off amazon and is cheaper than buying a new unit, same with leaking rings or seals. but if a part of the tank is cracked or something like that you might up spending almost as much to replace a piece of the unit as it would be buy a whole new unit. Amazon has this model for 180$ if repairs would cost more than 80 I would say replace it, these things dont last forever, especially if you live in a cold place that freezes in the winter and it sits in the sun all summer.
Hayward S166T Pro Series 16 Inch Top Mount Pool Sand Filter Hayward SX164DA Lateral Assembly with Center Pipe Replacement for Hayward...
Hayward SP0714T Pro Series Vari Flo Top Mount Control Valve
Hayward SX164AA1 16 Inch Filter Body with Skirt Replacement for Select...
There was also a couple smaller parts on amazon but you should check it out and also compare them to some other places.
Aug 09, 2015 | Hayward Pool & Spa
Hayward pro series s244 im getting large amounts of sand in pool and the system is drawing lots of air what could be wrong
Either broken lateral drain assembly or the manifold.
If fairly new filter, it could be that you have overfilled the amount of sand, as it is too close to the bottom of the variable position Multiport filter valve.
Hayward SX244DA Lateral Assembly With Pipe
May 24, 2015 | Hayward Industrial Products Hayward Pro...
When backwashing...sand discharges out backwash hose..
A little sand in backwash is not uncommon. Many packaged sand filter systems use pumps whose flow rates greatly exceed the flow capacity of the filter.(the more horsepower the better, right? - Wrong) If this occurs only during back flush the the pump is too strong or the sand level is above the beginning of the rounded top of tank. The sand level will eventually correct itself.
Aug 10, 2012 | Hayward SAND FILTER, PRO SERIES
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the hayward model sp 711
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
How to refill the Hayward s200 sand filter for above ground pool
Fill the empty and cleaned tank about half way with water, cover the stand pipe in the filter with a plastic cup or some other means to ensure sand will not go down the pipe. Be sure the pipe is centered in the hole. Add 200# of #20 silica sand and once filled use your hand to reach in a level off the top as best you can. The sand will be about half way up the filter and now the water will be near or over the top. Once done, secure the valve in place and connect the hoses and you are ready to go.
May 18, 2010 | Hayward SAND FILTER, PRO SERIES
Instructions on placement of the lateral assmebly w/center pegs
That placement is automatic based on the center pipe resting on the bottom of the filter tank and the valve being fully seated into the opening on top of the filter and clamped into possition. You likely have damaged laterals and need to replace that assembly in order to fix the sand issue. When refilling the tank with sand, be sure to fill it nearly half way with water before adding the sand.
Jul 15, 2009 | Plumbing
Sand coming out of my sand filter into the pool after changing the sand in the filter
Replace the lateral assembly. Be sure to fill the tank just under half way with water before adding the sand back in. Otherwise you risk cracking the laterals.
Jun 14, 2009 | Hayward Pro Series 18" Above Ground Pool...
How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
277 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
