Question about Lenovo ThinkPad R61 Notebook
Laptop wont turn on just does 16 beeps - Lenovo ThinkPad R61 Notebook
  • 553 Answers
When you first turn your computer on it runs a series of test called the POST, which stands for Power On Self Test. When your computer fails one or more of these test the computer sounds a sequence of beeps that let you know which test(s) were failed.
These are different for different models of computers. You can go to your computer manufacturers web site and do a search for "POST error codes" to find out just what the code means for your computer.
This does mean you have a hardware problem. If you're not real savy with computer electronics you most likely will need to take it to who is but check the codes first, there's no need to pay someone if the problem turns out to be bad enough that the computer isn't worth repairing.
Best of luck to you.
Posted on May 02, 2010
Ipad mini wont on after pushing the home button
try removing the battery for several minutes , them put back in
Apr 05, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My gateway laptop nv series screen wont turn on when i boot up my laptop
you must take note to the beep of you laptop. when you turn the laptop op it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reapplied every 3-6 mouths max.
Oct 24, 2013 | Gateway Computers & Internet
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
When i turn it on just the green lights and nothing on display with 16 beeps
There are lots of reasons for the beeps. Most of the time its a hardware issue and most of it is the RAM. Please red the below link and hope it would be of help.
http://www.computerhope.com/beep.htm
You may try to do some isolation of the problem. You may
  • remove the RAM memory and check if the beeping stops
  • remove the Harddrive and check if the beeping stops
  • boot the computer using external device like USB CD/DVD Drive, floppy drive with DOS...etc and check if it goes through.
From here you would know what causing this error. Hope this helps.
Jul 20, 2011 | Computers & Internet
T500 lenovo kepps beeping and wont turn on it just keeps beeping. i turn it off i took out the batter and still the beep is there and the computer wont turn on
remove the power supply and battery then remove the memory module, clean the memory gold contacts. a regular pencil eraser will do. return the memory then the battery.
Apr 19, 2010 | Lenovo ThinkPad T500
Monitor wont work when i turn laptop on i hear 1 long beep then 2 short beeps
then have your memory or vga card check if you hear this beep sounds it is a memory or vga hardware failure, take your notebook to a certified laptop tech, if you want to troubleshoot but unsure on what to do, better have it check by an expert to avoid any more damages to your unit
Nov 24, 2009 | HP Pavilion dv6000z Notebook
When turned on loud beeping sound black screen
i sounds like a graphics problem but try and re seat the memory 1st. disconnect anything connected to the laptop, unplug it and remove the battery. remove the memory module(s) and re seat them. but the battery back in, plug it in and restart it.
Aug 07, 2009 | Computers & Internet
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Lenovo ThinkPad R61 Notebook Logo
235 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
