Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
No suction on floor part
There is suction on the hose part, but none on the floor. I clean the filter every time I use it. Have checked everything else. It is Dirt Devil featherlite 12 amp. Motor runs, brushes turn, but no suction. What is it?
  • 294 Answers
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on May 02, 2010
  • Nikcole May 29, 2012
    Worked!!! So glad i found this..I was about to toss my vacuum and buy another!
This solution was dead on! There was a wad of cat hair, MY hair and sawdust that my boyfriend decided was OK to sweep up blocking the curve of the tube leading from the foot to the canister. Got it out with a hemostat and it works like a dream now. Watch out for long girlie-hair wadding up your tubing.
Posted on Aug 15, 2010
  • saved7606 Jul 14, 2011
    Yes man took mine apart at the elbow and girly hairs were clogging it up.........can't live with em can't live without them....LOL...........nothing but wadded up hair ..........at least I know thanks to the internet and friendly people..........God Bless
3 Suggested Answers
galati2k
  • 281 Answers
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
Posted on May 05, 2009
  • 731 Answers
SOURCE: Dirt Devil 086905 has suction
Need to take the head apatr as if you were replacing a belt. Look for the clog... it's there
Posted on Apr 01, 2011
My Dyson Vacuum DC24 suction loss.
You sound pretty savvy in your troubleshooting. Take a look at this video. You may have a split in one of your three suction hoses. I tried to find a video for a DC24 but to no avail. These two models are pretty close and this video should help you out.
Dec 04, 2017 | Dyson Vacuums
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have changed the hepa filter & made sure the washable filter is clean. I checked the brush & it's working fine. The indicator is still red very little green. Not suctioning good at all. What...
check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself and you will need to take the unit into the repair shop and have the motor rebuilt or replaced.
c..
Feb 02, 2011 | Bissell 3920 Bagless Upright Vacuum
Thehose has no suction
remove and clean the filter. you can use a air compressor to blow it out or use a brass wire brush and tap the filter on the table until it looks nice and clean,, this will return the suction to your vacume. also at the same time as you are cleaning the filter, check the hose for any blockage ( especially down by the floor sweeper where the hose kinda bends down into the unit ) -- when a filter is dirty and the suction is not that great, dirt loves to collect and compact in this spot,, use a wire coat hanger to fish out and clean any debris.
c...
Jan 05, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
No suction coming from the bottom of the vacuum
9 times out of 10 there is a hose blockage at the point where the hose bends down to the floor. remove the suction hose and clean and clear any dirt build up inside the hose. also at this point it is a good idea to clean the filter. ( remove and brush out or use a air compressor to blow filter clean ).
c...
Dec 31, 2010 | Vacuums
Low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
No suction
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
964 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
