Question about Garden
Hot chain saw wont start
My Sears 358.352161 16'' chain saw starts great when its cold. when I run it for 15-20 minutes and shut it down for a short time it wont start. Any suggestions?
  • tksvy1 May 02, 2010
    Thanks, I will let you know the next time I fire it up
  • dontbother10
    dontbother10 May 11, 2010
    Loosten the fuel cap after you shut it down and let us know if better. I think the fuel vent may be bad. The fuel gets hot, vaporizes, pressurizes the tank and floods the engine. Reply below please.
    Problem Solver:
  • 16 Answers
Mine did same thing stopped using universal gas mix and went back to original manufacturers mix saw cooled down and never did it again
Posted on Jan 15, 2011
  • creekkid Apr 27, 2011
    older saws use 16:1 gas oil mix and will overheat if 30:1 or 40:1 is used .
    Brigadier General:
  • 4,088 Answers
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
Posted on May 04, 2010
Craftsman 18" chain saw 42cc. Starts and runs fine. Will not idle after running for a while. Will not restart when hot. Will start after the saw cools down.
I had a 2 cycle snow thrower that acted similarly. It needed a new diaphragm. When they get old they act up. I could never see a physical difference between the good and bad one but the new one fixed it. It's a flat rubber part that is in the carburetor. Call Sears parts or visit them on-line to get a parts breakdown of the carb.
Feb 22, 2015 | Craftsman Garden
What would cause a poulan chain saw to quit running after about ten minutes of cutting
The only temperature sensitive part I can think of is the condenser. In most saws it is under the flywheel with the points. Some newer saws have an electronic ignition module. If that is the case the module must be replaced.
Oct 15, 2014 | Poulan Garden
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
Husqvarna model 450 will not start when hot
1 view piston. To do this, remove the muffler. 2 to change seals on crankshaft.
May 31, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hot start problem with husqvarna 261 chain saw
hi robert
you need to change the seals
all the best savumihai71
Aug 16, 2009 | Husqvarna Garden
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Jul 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
