Question about Fuji FinePix Z1 Digital Camera
Zoom error problem
My camera keeps on writing zoom error when it is switched on and cannot snap any picture...
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 01, 2010
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera. Card's write protect switch is set to lock
i try to write protect my pictures on my camera canon eos rebel t3 after that i cant snap i cant do anything when i press the shutter button then it write cards write protect switch is set to lock please help me
Feb 06, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Once u zoom into the picture that is very far away how do u keep the picture zoomed in after u snap the shot ...
Once you've framed your shot (zoomed in) and taken the picture. That's it, the picture you've taken is the one in your view finder, and that's the way its kept.
However, if you want to zoom in further, you can using the software you were provided with your camera, you can, you can also zoom in using your camera menu. Once happy you can then save the edited picture. But this time its a digital zoom and it will reduce the resolution. The picture won't look quite as fine. It will be a balance between picture quality and the extent you want to zoom in.
Apr 19, 2011 | Olympus PEN EPL1 Body only Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Shutter not opening fully while taking snap
Hi there
Try spraying the shutter with WD-40 and keep on opening and closing it until it works properly
Good luck and regards
Jan 07, 2009 | Canon PowerShot A470 Digital Camera
Faulty d40x
I would start by looking at all of the push buttons on the camera. One may be stuck down.
Jul 23, 2008 | Nikon D40x Digital Camera
Casio Exlim--camera
Try resetting your camera. In your picture taking mode press MENU. Go to the SETUP tab and go up until you see RESET. Press your right arrow and make sure reset is highlighted and press set. If that doesn't work the Call the repairs center at 800-706-2534 and then keep choosing option 1.
Jul 02, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
What does LP stand for
Have studied the Manual carefully for possible error codes? If you are not getting a result there the try the Technical Support Team at Samsung
Jun 17, 2007 | Samsung Slim Zoom 1150 Point and Shoot...
80000 snaps
I would think it implies the camera / flash / whatever is still functioning after that many operations (pictures)... of course everything wears out eventually, film, digital cameras and flash too. In this year I may hit 15,000 pictures with my FZ10... I expect the mechanical (zoom, doors, buttons & switches) will last several years. My vivitar 283 flash units may hit 2,000 flashes this year.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Fuji FinePix Z1 Digital Camera Logo
297 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
