Question about LG L1932TQ LCD Monitor
No power, fuse looks good - LG L1932TQ LCD Monitor
  • 11,361 Answers
Caps look OK? Please look through the albums so you will know what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Please post back what you find. Pictures will help a lot.
Posted on May 02, 2010
What causes 15amp eng fuse to blow as soon as I change it , on kia k2700 diesel 2006
a short to ground pull pos cable off battery load test battery if good ,l\follow power back to fuse box looking for breaks pinches or other things that would cause a short. Look where the wires go throught the cab , make sure the fuse block bolt is tight if it has one . look for hot spots in fuse block repair as needed good look around any place that power is run to it
Dec 12, 2014 | Kia Cars & Trucks
2011 honda pilot accessory port failure
remove what.
i bet you didnt know there are 2 fuse boxes.
check all fuses in both boxes.
or read the drawings on alldata.com
see what fuse powers this acc. port.
the inverters suck big current and will blow a power port in jiffy
(read amps on inverter, and see, wow huge)
1000w is 83+ amps.
500w is 40 amps. both are fuse killers.
fuse that look bad are
fuses that look good, can in fact be bad, hair line cracks
use any ohm meter on low scale, 0ohms good. infinity bad.
to test any fuse.
Jan 10, 2014 | 2011 Honda Pilot
1997 camry no power to radio
fuses that look bad are.
fuses that look good , can be , in FACT bad.
DMM, (flip to low ohms)
fuse reads 0 ohms, its good
fuse reads infinity its bad.
if fuse is good check for 12 at the radio power wire.
the radio must be ground do work, is it?
some radios have a separate ground wire (black) is it grounded?
post new radio make and model and can answer with 100% accuracy.
im a retire ET.
DC to daylight. experances.
Dec 24, 2013 | 1997 Toyota Camry
Instrument cluster and power windows both lost power at same time
fuses.
fuses that look bad are,
fuses that look good can in fact be bad,
use the DMM , press ohm.s
0 ohms good,
infinity bad.
the DMM will never lie to you , if battery is good and fuse in side good
we test the ohm scale by shorting the leads and see, 0 ohms.
my meter is working, i can now test fuses.
this is SOP
standard operating procedures.
Sep 14, 2013 | 1990 Honda Accord
No power to cd player or ceiling light grand vitara 2003
fuse, called dome fuse is blown, or radio fuse.
fuses that look bad, are, fuses that look good, may be...........
check fuses with an ohmmeter, fuses that look good can have very tiny cracks and are not good, only an ohmmeter works, on fuses with 100% accuracy. (a volt meter works in circuit even better !!!)
Did you test the dome lamp to see if it really works?
pull it , put across 12v battery ,does it glow?
did you look at the radio. and see if it has its own inline fuse?
did you hot wire the radio power wire to see if the radio even works at all?
if you have DMM with voltmeter this is so very easy to trace.
ask.
Feb 24, 2013 | 2003 Suzuki Grand Vitara
Having a problem with my 300te 1991. No power too cd player, clock or the lights inside the car. I looked in the fuse box. And all these thing are on the same fuse. Fuse is not blown.. Any ideas?
electrical problems are a headache for sure. Get a good test light and test on both sides of fuse while still in the fuse box. If you have current on both sides the problem is in the wiring to the components. If no power to either side start testing from fuse to main power. If no power to just one side the fuse might look good but is bad = replace. Hopefully just a fuse.
Dec 21, 2011 | 1991 Mercedes-Benz 300 Diesel
How do find the radio fuse when it is blown
Easy way. With a test light connected to ground ( a test light is a tool that looks like a ice pick with a clear handle with a bulb inside, and a wire coming out the end with a clip on it) Connect the clip on the light to a metal ground under the dash and with the fuse panel where you can see it, touch the pointer to each side of the back of the fuses, with the key on. The light should lght on both sides of a good fuse. If a fuse lights the light on one side and not the other it's blown. For the radio to work three fuses all need to be good as theirs all the time power and key on power and lighting as the dash lights power. The cigar fuse many times provides the all the time power, But if it's blown the radio won't play. Pull one fuse at a time and look at them to see if the bar inside the fuse is good ( they can look good and be bad) back to the test light meathod, Look the fuses up in the owers manul and it'll tell you the location of the fuse but the radio fuse can be good and the radio strill not work as the cigar fuse has to be good too, There;s another fuse panel under the hood that has the main fuses near the battery, Again the test light is fastest and easiest as any fuse blown even though it's not the radio fuse can make the radio not play. Aftermarket radios can have inline fuses instlled by the radio installer and some have fuses right on the back of the radio.
Jun 24, 2011 | 1999 Mercury Grand Marquis
12 v dc power outlet no power. i have checked the fuse in the fuse block it is good. Is there another fuse in line with the power port or something?
You may check the acessories fuse on the side of your dash. It may be no good either. You can look at a fuse, but the does not necessarily mean it is good. Your best bet is to just replace them period.
Jul 03, 2010 | Cars & Trucks
95 jeep cherokee no rear taillights,but rear blinkers,and brake lights work fuse #19 looks good also lost dashboard lights fuse#9 looks good
check fuse #15 and see if it is the problem. also look under the hood in the power distrabution box at fuse #13 (15amp mini Blue fuse) that could be the problem as well
Nov 29, 2009 | 1995 Jeep Cherokee
Radio no power 2000 vw beetle.
you may try checking the fuse box and see if the radio fuse is broken, if it is, try to raplace it.
Jul 16, 2009 | 2000 Volkswagen Beetle
LG L1932TQ LCD Monitor Logo
113 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
