Question about Kirby G5 Bagged Upright Vacuum
How do i replace the belt i took it off to clean it
  • 438 Answers
Hi There,
Here's a very helpful video that we've shot showing you exactly how to replace the belt on a Kirby Generation series, including your G5. The video also shows you how to perform basic maintenance on your roller brush to prolong the life of the belt as long as possible. If you haven't already purchased a belt, and need to buy a new one, here's a link to the exact belt that's used on your repair:
Kirby Generation Belt:
http://www.govacuum.com/kir184.html
Here's the video:
If you have any follow up questions, please feel free to use the comment section on this repair page, I'm always happy to answer follow up questions.
If this video helped you, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated.
Chris Jones
GoVacuum.com
Posted on May 01, 2010
My floor brush is not turning or picking up dog hair/dust, I took it apart and cleaned
Be sure to install a new belt, belts lose elasticity and need replaced once or twice per year.
Feb 08, 2017 | Vacuums
How do I put on belt? cleaning lady took old one off so I'm lost. It's a hoover turbo 3000.
Assuming this is an upright vacuum, the belt is located under the bottom case and runs between the motor drive pin and round the brush or beater bar. After removing the screws to expose both of these pull up on bar, wrap belt around moter drive, replace idle side of bar, insert bar into belt and stretch to drop into place.
Mar 23, 2015 | Hoover Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Brush won't turn
Even though the belt is still in tact, that doesn't mean that it is still good. The belt needs to be replaced with a new one because it is stretched. It is probably slipping on the beater bar.
Jim
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No carpet cleaner coming through
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacume brush won't turn but belt is not broken
The belt is probably stretched and won't drive the brush roll. Also check the brush roll, the ends should turn freely, if no, then replace it also.
Mar 20, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Kirby G5 Bagged Upright Vacuum Logo
261 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
