Toshiba 4mb jump drive
My computer doesn't show the flashdrive when i plug it in. Any help would be appreciated! Thanks
  • flapjackchar Feb 01, 2009
    i cannot use the mini cd also when i try to download the driver from www.dynexproducts.com but the file doesnt open
Right click on My Computer and select Manage. Find your jump drive and assign a new letter. Exit manage computer and see if it auto recognizes.
Posted on Oct 15, 2009
  • 871 Answers
Try to jump from one usb slot to another until your computer recognizes your flashdrive.
Posted on Mar 25, 2008
SOURCE:
Flash Drive (Kingmax) cannot be read by the computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 06, 2012 | Electronics - Others
I have a PNY USB 4GB Flashdrive, and when i plug it in, it shows that it isn't plugged in. I try to look for it, but it shows nothing is plugged in. Please Help!
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 13, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Hack Crossfire
Help me please , My USB Toshiba 8GB show only 4MB
Oct 26, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I download pictures from my computer onto a usb-16gbtr, there are no instructions with the flash drive
Just plug the Flashdrive into the USB port of any Computer and the Operating system ie: Windows should just pick it up with Auto play after a few seconds. Open the FLashdrive under My Computer?Computer(depends on the version on windows you are using) Open the Mass Storage device or the drive that shows the Flashdrives details and then just copy your pictures from the folder which you saved them and then Paste them into the Flash drive.
If you want a more detailed description, just let me know what Windows or Operating sytem is on your Computer or the device you want to download from and also the make and model of the Flashdrive.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Jan 31, 2011 | Computers & Internet
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Open Questions:
Aol verizon Tech support number 1=855=536=5666*$ -Aol verizon Customer Support- PYQCPMH [email protected] assistance available 24*7. If you are facing any issues in printer you will get expert assistance through [email protected] helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. [email protected] SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... [email protected] Support Phone Number +{1-855*536*5666*} to resolve all [email protected] products. is an American multinational company which was founded by Michael [email protected] its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. [email protected] is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, [email protected] number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees [email protected] cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL [email protected] cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. [email protected] cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America.
Oct 21, 2019 | AOL Computers & Internet
Computers & Internet Logo
265 people viewed this question
Ekse
Marvin
Marvin
