Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Sears Craftsman riding mower V belt getting chewed
Just replaced riding mower V belt. It immediately started smoking and getting chewed up - frayed along the edges. The belt and pulleys felt hot. Anyone have an idea what we did wrong? thank you very much
Its a Craftsman 18 Hp 42" Deck Lawn Tractor
917.273398
the browser made me choose 20 hp in order to post the question...
    Sniper:
  • 52 Answers
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
PRIMARY BELT SIZE
I WOULD SUGGEST HIGHLY YOU GET REPLACEMENT BELTS FROM SEARS . THE AUTOMOTIVE BELTS ARE IN ONE INCH INCROMENTS SEARS BELTS ARE IN HALF INCH .. GET YOUR MODEL NUMBER AND CONTACT YOUR LOCAL SEARS OR K MART . FOR THE PROPER BELT ! .. JUST THE WAY IT IS WITH CRAFTSMAN MOWERS ... SORRY ....
Oct 21, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I replaced the cutting belt (obtained at sears) on my 19.5 HP Craftsman tractor and the belt is smoking. What normally causes the smoking to take place?
also make sure you have the belt on correctly and all pullys will spin freely . also check the guide bars ( if equipped ) are not rubbing the belt when its under tention . signs of smoke means the belt is not able to spin free like it needs to . most of the time its something simple that has been over looked ...
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a sears ridering lawn mower . The problem i am having have replaced the belt but it keeps chewing it up.
is the belt in alignment? check pulleys without belt on are there any with notchy or harsh bearings? are the belt guides too close to pulleys causing belt to heat and fail?
Aug 13, 2010 | Craftsman Garden
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
May 15, 2010 | Craftsman Replacement Belt for 42" Deck
Need belt diagram for Craftsman riding mower
Try the link here but use the MODEL number instead.
Hope this helps!
Oct 01, 2009 | Garden
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
1,252 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
