Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
D-LINK wireless router does not work
I upgraded the wireless router firmware via wireless and later found out that i was not supposed to do that.The wireless router does not work. The router boots and allows you to connect a computer to it via the four ports on the back. When the router boots the wireless light does not come on. PLEASE HELP!
  • 78 Answers
If you can enter router configuraion site you needs to continue setup wizard or try it manualy by getting to ip configuration site
192.168.0.1
or try to reset router for 1 min
Posted on May 02, 2010
TL-WR740N wireless router not working
I don't have the same router, but my router requires the reset button to be pressed and held for 20 seconds. Try that. Also, I have found the manual on-line. Try the link below:
https://www.manualslib.com/manual/534658/Tp-Link-Tl-Wr740n.html
Sep 30, 2017 | TP-LINK TL-WR740N Router
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Suddenly unable to connect wirelessly to dir-655 but still able to be connected via wire connection
Login to the router interface and check the wireless settings,change the Wireless channel to 9 for the 2.4 Ghz and also look for the firmware upgrade.
Mar 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I'm trying to upgrade the firmware on a belkin wireless router
upgrade of Firmware is at your risk...
never upgrade Firmwares....they are not ment for that....
your hardware may be rendered useless after firmware upgrades....the chip inside your hardware is programed to run based on a certian program installed as a firmware from the factory....sometimes upgrades will screwup your hardware....so be careful and do it at your own risk...
Dec 10, 2009 | Belkin (F5D7230-4) Router (587009)
Unable to reset router
Try going to D-Link website for firmware upgrade to this model, Also make sure u download the the firmware for the version of windows you are using. In order to upgrade, the router must be hard wired that is connected directly to your modem as unit will not upgrade using wireless connection.
Hope this helps you!!
Nov 20, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Where can I find a firmware upgrade for my wgr-200
Try this link...Hope this helps!
http://search.support.gateway.com/iphrase/query?command=text&attr1=&attr2=&t=0&text=firmware+upgrade+for+my+Gateway+wgr-200+router&x=22&y=11
Sep 06, 2009 | Gateway Wireless-G WGR-200 Router...
Power Light Blinks, can't communicate with Linksys Network Adapte
Seems to be a common issue among these routers. If you tried to upgrade the firmware via wireless connection then it will generally fail. It is recommended to upgrade through the wired connection. In most cases if the upgrade failed and will not reset, most likely the firmware on the router has been damaged. Your best bet is to purchase a new router.
Mar 14, 2009 | Linksys Wireless-G WRT54G Router
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
149 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
