Question about LG LW7000R Air Conditioner
My lg lwhd7000hr air conditioner won't turn on there is power to the cord and the reset button stays on.
  • 674 Answers
Does it have a position for fan only? If it does try that and see if the fan will run. If it doesn't something is keeping power from getting to the fan and compressor. Try looking inside for a fuse or possibly a capacitor. There may be a small transformer inside the unit. Check it for 24vac. If the fan runs then the transformer should be ok.
Posted on May 01, 2010
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
Where is the button to reset on a frigidaire air conditioner
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
Jul 23, 2014 | Frigidaire Heating & Cooling
Why does the unit beep when I plug it in.
Good Morning Tina,
I understand that your Frigidaire air conditioner, model# FAM187S2A, beeps and flashes lights when you first plug it in. First, test the power supply cord by doing the following:
1. Plug in your air conditioner.
2. The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3. Press the RESET button. Again you will notice a click as the button engages.
4. The power supply cord is now supplying electricity to the unit. (On some products this is also indicated by a light on the plug head)
NOTE:
• Do not use this device to turn the unit on or off.
• Always make sure the RESET button is pushed in for correct operation.
• The power supply cord must be replaced if it fails to reset when either the TEST button is pushed, or it cannot be reset. A new one can be obtained from the product manufacturer.
• If power supply cord is damaged, it CANNOT be repaired. It MUST be replaced by one obtained from the product manufacturer.
NOTE: Some plugs have buttons on the top.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
I have an LG air conditioner, Model LWHD800R. The power chord has an adaptor with two re-set buttons which plugs into the wall. Both of these re-set buttons no longer work. Without the re-set feature, I...
Just replace the cord. I am unfamiliar with your unit so you may need to buy a new cord form the manufacturer but there is no reason to replace the whole unit.
Jun 16, 2011 | LG Heating & Cooling
My A.C doesn't turn on
cause don't use an extension cord. probably fried the gfi or burnt other wires if you have a meter just test it
Jun 05, 2010 | LG LB8000ER Air Conditioner
My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Mar 27, 2010 | LG Electronic Window Air Conditioner
Zenith ZW6500R Air conditioner No Power
The reset button on the power cord has to be really pushed in until you feel a click. It is a soft button, so you might think you have pushed it in enough but you must feel the click. After the first reset you no longer have to press the button unless you have other electrical power issues that trip the button.
Aug 16, 2009 | LG Heating & Cooling
I have an LG room a/c Model # LWHD7000HR that
I am having the same problem. Have you had any luck, yet?
Jul 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG LW7000R Air Conditioner Logo
730 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
