Question about Homelite Mighty Lite Lawn Trimmer
Is the primer bulb suppose to have gas in it this is a homelite
Is the primer bulb suppose to be full of gas and which line goes to the bulb and what goes to the carb. overflow to bulb?
    Sniper:
  • 52 Answers
Here's a sketch that might help you. The primer bulb will keep fuel in it. is the primer bulb suppose to have gas in it this  - 3985d0d.jpg
Posted on May 02, 2010
Homelite UT-08544 fuel line which one goes to bulb which one goes to carb
I wish those posting answers could get things right.
The remote primer does not push fuel into the carburetor; it for pulling fuel mix through carburetor removing air line the system.
Here is the basic setup for a remote primer.
Apr 02, 2015 | Homelite Garden
I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Jun 17, 2011 | Homelite Garden
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
When i press the primer bulb air goes into the gas tank but no gas goes into the primer bulb.
Check the fuel filter for plugging. Check the fuel lines for decay or other damage. Inspect the primer pump carefully for any cracks or holes in the bulb part. The primer is supposed to pull fuel through the carburetor from the tank supply line and filter and return it to the tank. Hope this helps!
Nov 18, 2010 | Poulan Garden
Fuel Lines
Off of the primer bulb there should be two lines, one goes to the tank, the other goes to the carb
May 04, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Need to replace the gasoline pickup tube on a Homelite SX135.
The typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 02, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,144 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
