Question about Hitachi P50H401 50 in. Plasma HDTV
Hi, I had the same issues with the blue light falshing 4 times over and over again. I replaced the digital neptune board that hooks up to the main input board and now I get a solid blue light but after 15-30 seconds the light turns amber/orange and I still get no picture or no light from the screen. Please help. what could be the problem
  • 1 more comment
  • Ahmose Avin
    Ahmose Avin May 03, 2010
    to expensive for me. Can you or someone else help me figure this problem out please. Thanks
  • Ahmose Avin
    Ahmose Avin May 04, 2010
    ok even if the tv was blinking blue before and after replacing the digital neptune board it is solid blue. the sound came on for a couple of seconds then went away. so the sustainer boards huh
  • Ahmose Avin
    Ahmose Avin May 05, 2010
    thank you for your help. I did some testing and found out the it was the sdr-d. The lower buffer board.
  • Hitachi Master
  • 12,061 Answers
Http://elektrotanya.com/hitachi_lc58_chassis_50vf820_lcd_projection.pdf/download.html
Above a service manual too, http://www.scribd.com/doc/3401783/Hitachi-Service-Manual-TV-Plasma-42HDT5055-Chasis-PT3G
Above a training manual for plasma.
http://www.fixdevice.com/smanuals/file/36673.html
Your exact service manual above.
http://www.tv.quuq.org/index.php?ind=downloads&op=section_view&idev=42
http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/
Above, first, Owners, next, Service manual links for differing parts of the set, above that is a Hitachi, training manual, above that is a service manual. Download them ALL.
OK, above are Service manuals and circuit diagrams. links To help you. These are the manual i use to train engineers to repair these types of units. IF you wish to try to fix it yourself, and I do not really recommend it. FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE, (It may be possible to do without it, as long as no waveforms need to be aligned, or observed) . Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Hitachi Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on May 05, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the X and Y sustain buffer boards. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged capacitors on these boards and replace whichever has gone bad. If still the issue is not resolved, then please check the power supply board. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment further assistance.
Thanks
Rylee
Posted on May 04, 2010
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one Hope this helped Robb
Purchased used last night. Working fine until I tried to hook the Xbox up then screen went black sound went out. Blue light indicates TVs on. Menu or input no longer displays on this TV y is that?
Hi. It could be one of a few parts
I.e main board you say the TV stays on I.e standby light stays on OK.
if so try shining a torch into the screen while the TVs on see if you see any pictureor menu when pressed on remote .if so possibly backlight issue.
try darken thye room your in when shining a torch at the screen
. What's your make and model number
as it could be tcon or main board issue even
Feb 03, 2017 | Televison & Video
Could the Main Logic Board in my Sony Bravia Ultra HD 4K XBR70X850B be bad?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 24, 2016 | Sony Televison & Video
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
Hi my drive powers up OK with flashing blue light then stops falshing and just makes regular clicking noises - not recognised by either my laptops or PC..
If it is a Western Digital hard drive, then the unit is toast. Thei probelm is very common with Western Digital when the hard drive is in failure.
Nov 18, 2010 | Computers & Internet
Blue light flashes 4 times but no power
U know basic electronics,have tools and know basic soldering?Take the tv aparts,the power supply,that board where the a/c power cord plug into it.That the power supply board,searches the power supply board, for those dying about to be dead,capacitors alway bulges up on it tops or puff up on it tops.Replaced these dying and about to be dead capacitors,the tv power will up again and work.Or tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | Samsung SP-S4243 Television
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hitachi P50H401 50 in. Plasma HDTV Logo
279 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
