Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster touchscreen The touchscreen on our leapster has stopped working. The game is approx. 2 years old. When I called Leap Frog, they said they do not repair these units. Is there any way to fix it?
  • 6 more comments
  • Hoytinkc Mar 30, 2008
    I am having the same problems with our leapster. Parts of screen not responding. Tried cleaning and wax to fill scratches ,no consistent operation with either fix.
  • poet69 Jun 30, 2008
    Has anyone spoken to the company because I have had the same issue and wonder if it is a factory defect?
  • headsandwich Jul 03, 2008
    touch screen not working
  • mmcshopping Aug 11, 2008
    Same issue.  Tried to calibrate the screen.  Removed the pen and reconnected.  UGH.  I'll try to call customer support now.  Have you tried to calibrate the screen?  Look here: http://gobaco.wordpress.com/2006/10/31/h...
  • Anonymous Aug 14, 2008
    yes. my mom bought three l-max for her grands (including two pink ones and one blue). they were hardly ever used for about a year and now they won't turn on even with the adapter. leap frog company says that it has been too long to return for free and that they will allow them to be repurchased for half price plus shipping.
    their response was " no one has problems with the l-max". it must all be a $300 figment of our imaginations.
  • Anonymous Nov 30, 2008
    help!
  • Anonymous Jan 04, 2009
    I am having the same issue with the Leapster Unit regardless of which game I use. I have emailed technical support only to find out that the unit cannot be repaired. They also said there are no recalls for the issue of being unable to calibrate the screen. Any other ideas?
  • Anonymous Jan 25, 2009
    I had the same problem on the Leapster2 and I posted my solution here:
    http://quicksolutionsforbigproblems.blog...
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Posted on Feb 22, 2009
  • 2 more comments
  • dbunis1 Jul 20, 2010
    Worked like a charm. Thanks
  • Jackie Fornstrom Oct 28, 2011
    Worked great!! Thank you!
  • Tia Alexander Aug 04, 2013
    tried this and when I get to the calibration screen with the first cross hair I can't press it b/c the system is not responding to the stylus. I have tried this several time and the same thing keeps happening. What do I do?
  • Linda Goodwin
    Linda Goodwin Feb 02, 2015
    Center x still does not respond
Re-calibrate the touchscreen!.. power up the unit while holding down the ?.. this willl take you to the units menu!.. press the "A" button.... this willl allow you to calibrate the touch screen.. first + mark to touch will appear in the lower left corner.. just thouch all the +'s that appear then restart the unit.. you should be all fixed..
Posted on Sep 30, 2009
Leapfrog recommends trying recallibrating the screen first (http://leapfrog.custhelp.com/ and go to customer support at the bottom and look for information on recallibrating the leapster). If that doesn't work clean the battery contacts with an eraser and dry cloth and replace all the batteries, then try recallibration again. If that doesn't work call their 4 hour support line and complain. They may offer a replacement.
Posted on Aug 08, 2008
  • docobrien Aug 08, 2008
    Leapfrog 24 hour support line is at 1-800-701-5327
Open the unit up (remove all screws carefully, remember where they go) and then wipe the screen off. My daughter's had ONE CRUMB on the screen behind the case that stopped the touchscreen from working.
Posted on Sep 04, 2009
Hey all,
I have 2 original Leapsters. The 2 I have would not be able to finish the screen calibration (ie power+Home+Hint+B button). It would not register the center target. You would use the stylus to push on it and it did nothing. So, I figured I could not mess it up anymore than it was, since it did not work. Took all the back screws off. Removed back cover. took all the board screws out( make sure you notate which screw go where). Removed the ribbon cable for the touch screen (marking with a paint pen its orientation. Removed all the screws on black touchscreen cover. Then I carefully removed all the boards and touchscreen. I cleaned the outside of the touchscreen with a amonnia free glass cleaner. I then on the opposite side of the screen from where the wide white bulk flat wires are. I took my fingernail and lifted and pulled the outer layer of the touchscreen apart from the inner layer of the touchscreen film.*** Making sure I did not pull it comletely off***. If you do you will destroy the touchscreen wiring. I then cleaned both inner and outer films inside the outer film and then blew it out with compressed air. I then re-stuck the film back to its original location and in reverse just put it back together. After it was put together I then ran the alignment program and walla it worked like a charm. Hope this solves many of your touscreen problems. I am an electronics Engineer so I knew this trick from my career. My daughters are very happy now. This may sound complicated, but I did this within a half hour. I might post pictures on the one I do for my friends daughter as hers is acting the same.
Posted on May 18, 2011
  • warren moliken Oct 20, 2011
    i tried all the recalibration instructions out there. the screen remained unresponsive. with your brave instructions i unscrewed the backing of the unit and merely cleaned the screen with screen cleaner. then ran a screen recalibration.
    viola! working unit! thanks, matey.
If you are careful, remove the 5 screws from the back, then remove the 2 screws from the circuit board. VERY carefully use a toothpick or small flat-head screwdriver (or even a fingernail would work) and stick it in between the casing and the screen. The screen should "peel" off and you can clean behind it.
Posted on Apr 21, 2010
Solution #4 was brilliant! The calibration method wasn't doing anything until I took the unit apart and cleaned the crumbs from the edges of the screen.
Posted on Mar 14, 2010
OMG!!!! Thank you all so much for the calibration instructions. I was ready to toss out 2 leapsters and 5 games. Wheww! Thanks alot!!!
Posted on Mar 22, 2010
CALIBRATION - summary of hints from here that eventually got our circa 2007 green leapster's screen recalibrated - in no particular order: 1) "home+hint+B" to get started, 2) "A" button next, 3) cleaned dirt from the gap between the plastic and the screen all the way around with a toothpick (seemed to be the KEY ELEMENT to get everything else to work), 4) be patient and keep trying until you see the targets - the first one should appear in the top left corner while the text is still on the screen, 5) if it doesn't work just right the first time try again, 6) unit should beep each time you press a target center. As Yoda might say "patience a virtue, is it not?"
Posted on Apr 17, 2010
Solution #4 was the one that worked for me! I tried the recalibration first from the Leap Frog site and it didn't respond. I did find a crumb under the screen when I took it apart and the recalibration worked after I removed it.
One note, though. I thought that I would have to clean the screen from the inside. The Leapster 2 unit doesn't give you access to the inside of the screen. Taking apart the unit did let me get the crumb that was on the OUTSIDE of the unit, but stuck in the corner where we couldn't see it.
Posted on Feb 14, 2010
The "Best Solution" Recalibration worked for me. I was at my wits end and about to toss it. Thanks so much. I have made a note about the "Crumbs" behind the screen too for future reference; in case the first solution doesn't work. Thanks so much again. It's amazing how someone giving a little piece of information can help so many people.
Have a Great Day!
Brenda
Posted on Apr 26, 2010
My Leapster L-Max touch screen is defective. 2/3 of the screen does not respond. I tried everything. I called Leapster and they refuse to acknowledge there is a problem although researching the issue online would prove otherwise. They were extremely unhelpful and since it is past the 90 day period refused to do anything to remedy the situation. I WILL NEVER BUY ANOTHER ONE OF THEIR PRODUCTS!!!
Posted on Jan 28, 2010
The recalibration instructions worked beautifully for me on our 2 year old Cars (Pixar) Leapster2. THANKS!
Posted on Dec 27, 2009
The BEST SOLUTION on this page worked straight away for us!!
Thanks to "nveley"! We're very grateful.
Posted on Nov 29, 2009
My 6 year old son has the Leapster and the touch screen does not work. I opened the unit and clean the screen on the inside, and it still did not work. I am thinking that maybe it could be the pen that is attached to the Leapster.
Posted on Nov 09, 2008
How though
Posted on Sep 26, 2010
Click start game for leapster. Mouse does not work. Keypad lights up but mouse does not. I have reset the keyboard and still nothing. Any ideas?
mcdevito75 here, Do you also have to re-set the mouse?? Refer to the instruction manual for info. Also does the mouse take a battery?? Call or visit Leap Frog online for more info.
Jun 26, 2010 | LeapFrog ClickStart My First Computer
My 4 year old got a Leapster 2 for Xmas from his aunt in the US unfortunately the box with the battery and start up cd went out with the wrapping. How can I get another battery pack and installation CD??...
My suggestion would be to purchase the rechargeable battery package. ($25 -35) I know the initial investment may be steep but it is well work the investment. Batteries are expensive and if your child uses it over the next 4 years you have saved a lot more! Besides, you won't have to hassle with calling leap frog and asking for a replacement part that still will probably cost you money! We got ours at Target and they do periodically go on sale. If you go to www.leapfrog.com and go to the "download leapfrog connect" under the "support" tab, you can download the cd that came with your game system. To hook your leapster to the computer, any USB cable will work. You could temporarily use the one from your printer or other auxillary device. If you want to, you can purchase one relatively inexpensively from a Staples, Office Depot or Best Buy. Now you should be ready to go! Hope this helps.
Jan 22, 2010 | LeapFrog Leapster 2 Learning System
The pen hs stopped wotking on our leap frog globe
If you are in the US, you can call their Consumer Services number at:
1-800-701-5327
They will be able to help you get a new one.
Thanks for using Fixya.
Nov 19, 2009 | LeapFrog Leapster Electronic Book:...
Leapster 2 has no sound
We got our daughter a Leapster2 for Chrstmas 08. One day the sound just stopped working. Called Leapfrog. They said to insert a cartridge, and turn the unit on. Plug headphones into the headphone jack. Then rotate the headphone plug-in 360 degrees,( It is easier to hold the heaphone plug-in and rotate the leapster2). Unplug the headphones and check to see if the sound works. Leapfrog said try it more than once, and if it does not work contact them,1-800-701-5327. We tried it and Hallelujah it worked!
Feb 15, 2009 | Nintendo Game Boy Advance Console
Leapster 2 will shut off right after the "important" screen
Just called Leap Frog and apparently this is a common problem (defective screen). As long as it was purchased within a year they will replace it for free. They ask you when and where you bought it. (You have to pay to send the broken one back it was like $5). Hope this helps.
Feb 08, 2009 | LeapFrog Leapster Electronic Book:...
I need to order a replacement pen for my leap frog globe
Call their Consumer Services number at:
1-800-701-5327
Jan 14, 2009 | LeapFrog Leapster Electronic Book:...
Broken Leap Frog Leapster Learning Game System
I purchased a Leapfrog Leapster in end of June sales last year for my daughter's birthday in October 2008. When she first turned it on it froze but after restarting played fine for 2 hrs then died and refused to work again. Fortunately I had kept my receipt (Target) but was still worried about it having been 4 months prior. They ended up giving me a store credit as they no more in stock at that store and I picked one up from another Target without having to pay the difference between my original sale price. I know you don't have the receipt but you could contact the place of purchase and ask them even if they are able to send off for repairs or put you in contact with the right people. Hope it helps a little ...
Nov 16, 2008 | Toys
Leapfrog Leapster doesn't read cartridges anymore?
HI my son has a LEAP frog MAKE SURE THAT THERE IS NOTHING OBSTUCTING THE CONTACTS( metal on the game and the cartdridge meet)
PLEASE RATE THIS HELP FiXYa EXPERTS HELP
Sep 01, 2008 | LeapFrog Leapster The Batman Strength in...
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
17,288 people viewed this question
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
k24674
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
