Question about KitchenAid 24 in. KUDP01FL Built-in Dishwasher
How do you repair or replace the door tension spring on a KUDP01FLBT2 built-in Kitchenaid dishwasher? Thanks
    President:
  • 949 Answers
If your door falls down or is noisy I have put together some instructions here on how to repair. You will need a kit part number 8194001, it is relatively inexpensive, let me know if you have questions.
Door falling down or creaking
Posted on May 02, 2010
My dishwasher door springs appear not to work and will not hold the door open. How do you replace or reattach the springs? Thanks, JoAnne
they actually arent springs, it is a cable and has probably broken or come apart. You can order this part through KitchenAid and replace yourself. Or call a repair rep.
Feb 10, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDK02CRBS the spring on the door broke? Is this a easy fix, where do you access the spring
Turn off the power to the dishwasher.
Remove the access cover on the bottom front of the dishwasher.
Lying on the floor,you can see the door hinges and replace the spring.
Feb 12, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
Kitchenaid Hinge tensioner
It is aall exposed on the outside of the unit. Discconecct the water, remove the two set screws attaching the unit to the counter, slide it out and you will see the damage left or right. The white plastci piece slips off over the metal clip and you re-attach the string, apply pressure to the spring and slip the platci piece back over the metal and you are done. You will spend more time removing the unit than repairing it.
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid KUDS01FL - door spring tensioner snapped - how do I fix / get parts?
Replaced the tension spring cords. The plastic portion of the cords had broken. I think this is desined to fail since it is such light plastic.
Aug 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid DW door spring
The door hinges are spring-loaded. One or both hinges have failed.
Items 2 and 3 at the link below are the parts that are needed.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135727
I am not aware of a service manual posted on the internet.
Hope this helps! Please post back with what you end up doing, OK?
Good Luck!
Feb 10, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
We have a kitchenaid KUDP01FLSS6 built in dishwasher, and the door pops open several times during a cycle. Is this something that can be repaired or is it just a common problem? Thanks!
You should adjust the spring tension on the door. There are 3 settings. Move it to a lower number to tighten the spring. Be sure to adjust both sides of the door to the same setting.
Dec 21, 2008 | Dishwashers
DOOR TENSION PROBLEM : DOOR DROPS; NO TENSION AT ALL
I have had this problem and had to replace the cable (cord) and/or the springs
Aug 08, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid Dishwasher
the tension springs are quite easy to replace. they are mechanical, so you should be able to just take them off and replace them with the new ones.
Jul 30, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDP01FL Built-in Dishwasher Logo
659 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
