My starter rope broke - how do I replace - Craftsman model 358.794731
I took all the screws out but can't seperate the two sides of the housing
SOURCE: the starter rope broke on my Toro mower and the
I cannot believe that someone suggested grinding off the rivets. If the bottom portion of the rivet falls down and gets caught by the magnet on your flywheel and you try to start it you are going to do some SERIOUS damage.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
SOURCE: Cannot remove starter housing assembly on Sears Blower Vac
Take cover off were the belts are located. turn power button to off! see if the shaft can turn with a wrench. That should turn 180 degrees. If stuck you may need to forch it. Then try to pull cord.
Good luck
