How do you replace a water tempature sensor (ntc) on a kenmore front loader washing machine. and where is it located at.
  • 11,896 Answers
What make and model machine do you have? I get give you much better instructions if I know this info.
Posted on May 01, 2010
F 24 error code
Hello there and welcome to fixya
the f-24 error code is a temperature sensor failure code
The NTC, or temperature sensor, is located under the bottom front of the wash tub. It is a small square black plug between the heating element terminals. In many cases the connector plug comes loose and simply needs to be reconnected.
If the NTC is defective, a replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites have helpful exploded view diagrams that you csan use for reference to locate and correctly identify the parts you need. The NTC is listed as item 26 under the "Tub and Motor Parts" heading. If the model number is correct, the part number you need is 8181705. The average cost is about $10. You can view an image of the part here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3128829&pn_=8181705
Apr 06, 2012 | Kenmore Elite 45986 Front Load Washer
Tip
Thank you!! Our Whirlpool front loader was showing the F-5 error. Thanks to some...
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F05” Error Code.
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful. If you have questions, or need assistance locating parts, please click on the following link and use the “ASK ME” feature for a quicker response.
http://www.fixya.com/users/jsrock516
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Tip
F05 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washing Machines
on May 28, 2008 | Kenmore Elite 45986 Front Load Washer
Stop work and is showing a code f 05
Water temperature sensor error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Dec 14, 2010 | Kenmore HE2 Plus Front Load Washer
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error
"F5" is a Temperature sensor (NTC) error. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
repairclinic.com
Prices vary between these sites, so shop and compare. The average cost is about $10. You can view an image of the part here:
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite he3t washer. It flashes f5 at the beginning of a cycle
Feb 04, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F24 code
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 24, 2009 | Kenmore 46462 Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
