Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
I have toro lawnmower starts for helf minut then shots off 22 inch front drive y-5tpxs 195
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Sounds like its not getting enough gass. It starts then dies because there isnt enough gas getting to the engine.
Posted on May 01, 2010
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
Dec 22, 2008 22 joulukuu 2008 - It began that I could not play CD's. - Se alkoi siitä, että en voinut soittaa CD. Now my DVP3010 dvd player is not able to play DVD's too. Nyt minun...
Please replace your DVD drive. There is a problem on the motor and reader of the DVD Drive. If your continue using this drive it will damage your disk. Have it replace so that it won't create errors upon using it.
Aug 12, 2010 | Televison & Video
22 in persoal pace 195 cc Tecumseh oil leaks onto
There is a crankcase vent on top that may be cracked or out of place causing the oil to leak or the upper crankshaft seal may be leaking.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawnmower appears flooded and won't start.
Actually all you have to do is take out the spark plug and pull the engine through several times. What has happened is the intake valve was open when you tipped the motor so when the fuel ran out of the carb into the engine it saturated the spark plug. You may have to by another spark plug to get it started or dry yours out very well. The main thing is to make sure that most of the liquid gas has exited the cylinder.
One more thing.... the float needle may have tilted a bit in the seat as a result of haging it tipped on its side. This is going to sound a bit strange BUT... grasp the handle and alternately bang the front and rear wheels on the ground a couple of times by lifting the back of the mower with the handle about 2 inches and drop it. Do the same by pressing down on the handle for the front tires. (2 inches and drop)
IT WORKS!
This should get you going. IF not just respond here and we can continue troubleshooting.
Kelly
Apr 13, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 22 won't start after non-use for a long time.
After that long without use, I would bet your carburetor is all gummed up.
You'll have to remove all the old gas and clean the carburetor. That would solve you problem. Don't know how?? You have to have someone do it for you.
You have a nice lawn mower though.
Dec 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 lawnmower wont start when you pull the cord it comes out about an inch then it locks where you cant pull it no more
Remove the plug then try and see if you can pull the cord any futher.If not you may have to dismantle the pull start and check the clips are not jamming.
Jul 06, 2009 | Toro Lawn Mower With Toro Power Tools
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
151 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
