Question about Mitsubishi WD62527 62 in. LCD HDTV
Timer light just blinks and tv never comes on. lamp is good, ballast board is good. please help. what can it be
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. I am assuming it is Mitsubishi WD62527 62 in. HDTV LCD Television as mentioned at the top of the issue. You'll need to first check all components on the power board and DM board and then would need to replace the faulty components. You'll need to use a multimeter to check the circuits and components. This will take 4-6 hrs or less/more depending on your expertise. If you do it your self you'll need an experience to solder and desolder components on the board. Be careful as any wrong solder can result in short and can cause severe damage to the TV. I'll suggest you to do this only if you have repair experience of TV's. Getting this done from a qualified tech will cost you around $200-220 including the components. And if any board is to be replaced then it'll cost you around $300-350. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 10, 2010
  • 10,515 Answers
The problem you are seeing is the Digital Module (DM) not booting up, usually caused by seven bad (failing) capacitors inside the module. This is a very common problem in this model TV.
Chances are, though (since the TV was not without power very long), if you were to keep the TV plugged in, and push Reset periodically, it may eventually boot up and turn on (these are borderline bad parts). But the next time the power flickers, it will do the same thing. Eventually the problem will get worse until it will not boot up again (which may be now). If it does start working again, please remember to save this information for later when you need it.
You would need soldering equipment and good soldering skills to change these parts. The capacitors are all 1000uf 16V at 105C. Capacitors with a higher voltage rating are preferred, space permitting.
If you would rather have an on-site technician replace these, the labor should be in the range of $150-200 (in my area, depending on location). The parts cost should be $35.00 or less. Most servicers will know of this problem and can usually repair it in your home in about an hour.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • Mitsubishi Master
  • 12,061 Answers
Http://www.retrevo.com/s/Mitsubishi-WD-62527-TVs-review-manual/id/276ag923/t/1-2/
http://service-manual.eu/model.php?id=2732
Ok, please find above your owners manual and below that is your Service Manual, this is what the engineers and technicians use to troubleshoot and repair these sets.. Use the troubleshooting procedures and you should be able to find and hopefully repair your set.
IF you wish to try to fix it yourself, and I do not recommend it. FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE. Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Mitsubishi, Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on May 09, 2010
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Posted on May 08, 2010
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Green timer light won't stop blinking
Hi,the most common failure besides the lamp it's the board that powers the lamp it's called the ballast.Most of the time that board was used to providing a lesser voltage to the old lamp so when you get a new one it uses more voltage(ballast has to provide 15 kv to power the lamp).The price of the ballast is less than the price of the lamp and it's something you can do yourself .This video is for a samsung but it will you an idea on how to replace it http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Have a bless one!
Apr 21, 2010 | Televison & Video
I have a Samsung HL56A650 DLP TV. The Standby/Temp and the Timer lights are blinking. It will turn on and then shut off. When it comes on the picture is fine but it only stays on for a few seconds. There...
Check ballast supply board that drives lamp and is attached directly with lamp, ballast supply board can cause of this problem, would be cause of smoke while tv shows picture for moment.
Mar 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60xs955 Sony WEGA. TV has no picture, no sound; green light blinks for a while then stays on. NO RED BLINKING LIGHTS. Replaced the bulb with no change in result. I would think it is NOT the...
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!
Nov 25, 2009 | Televison & Video
Tv will not stay on
If the lamp light is not on, then the TV is flashing because of overheating or because of a fault.
Try first unplugging the TV and leaving it unplugged overnight, this will drain power completely and may solve some problem.
If the TV keeps having a problem, then there is a fault.
Many units have more than one fan (one for lamp, one on ballast, one on board). In that case ensure that all fans are working.
If the problem is not a fan, then parts can cause the problem are ballast board and DMD board.
In that case the parts must be tested before replacement.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts.
May 16, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Turning off
Three blinking lights indicates a lamp problem.  This can be from A) a bad lamp, B) bad ballast C) bad Light Engine/DMD Board.  Try replacing the bulb first.  As with any lamps, it has a limited life.  If that doesn't work, you can try the ballast next.  If that doesn't work, it's time to take it in to a certified repair center for diagnostics.  Here is a page from the service manual on the three blinking lights.
Jan 14, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Zenith E44W46LCD 44 in. Rear won't start
The buzzing is the ballast for the lamp trying to light the bulb. From what you've described it is a lamp failure. It's not that hard to change but you'll have to obtain a new lamp first. You can try and buy it from LG (800-243-0000) but I'm not sure if they'll sell to a consumer. Then you have to reset the lamp timer after you replace it. Hold the mute on the remote and the enter button on the tv at the same time for about 8 seconds and a screen will come up asking if you want to reset the timer. Just follow what it says to reset it.
Jan 02, 2008 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WD62527 62 in. LCD HDTV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
