Question about Canon imageRUNNER 5000 Copier
Copier key removal
I have a ir5000 that has a copy key installed. The person that donated the copier to us needs the key back. Can you tell me how to uninstall the key box so that the coper will work without it. Thank You Chuck
  • 161980 Jun 23, 2008
    error is E246
    New Friend:
My ir 5000 error code e246 how to clear this problem sir
Posted on Oct 16, 2013
E246
Posted on Jun 23, 2008
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
How do I remover personal information from my mp160 as I want to donate it
Normally there is no Information stores in printers. But for your safety said, you can remove the cartridges and reinstall it and then donate.
Regards,
Ron
Mar 23, 2011 | Canon PIXMA MP160 All-In-One Printer
I have Copier ir5000 the result of output is dirty, there is always black strip on the left long side of the paper (Legal Portrait) what could be the solution for this problem
There could be two problems I can think of. Is the fuser roller damaged? If that not then the drum cleaning blade may be bad. Hard to tell without actually seeing the copies.
Jan 13, 2011 | Canon imageRUNNER 5000 Copier
My laptop keeps asking me for a product key, what should i do? i'm afraid i might not be able to use microsoft office.
If the copy of office you're using came with the laptop but didn't have a disk and code it was just a trial and you will need to buy a copy. If you already have purchased a copy and installed it you need to open it up and look on the opposite side as the disk. You will see am orange sticker with the product key. If you have the trial version and do not wish to purchase a copy, you can remove the trial and install Open Office which will work with the Word, Excel and Powerpoint files for free from www.openoffice,com
If you choose the last option, please consider donating a few dollars as the entire program and all it's programmers are supported by donation.
Hope this helps FixYa,
Chris
Jan 06, 2011 | Microsoft Office Professional 2007 Full...
We have a Sharp AR-M355U copy machine that we are going to be donating to a local charity. I was wondering if anyone knew if there was a hard drive on this machine, and if so, how would we go about...
Sim 62-1 will reformat the hard drive if there is one. On the key pad press POUND-STAR-CLEAR-STAR and enter SIM 62 copy button 1 copy button. If you cant get into sim 62 there is no hard drive. If you can get into sim 62-1 then follow the display press yes. and that will reformat your harddrive.
Aug 26, 2010 | Sharp AR-M355U Copier
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
How to read copy counts on Canon copiers
press the counter key above the numbers keys
Dec 08, 2008 | Canon NP 6050 Copier
REMOVING REGISTRATION ROLLER FOR CANON IR5000
open the duplex then take it out from the mechine and see the roller out side the edges you can find c look remove it then
Oct 31, 2008 | Canon imageRUNNER 5000 Copier
Accessing ir5000 engineers console
You do not need humidity readings. If the copied paper curls at the edges as soon as it comes out of the unit, the paper (not the copier) is humid. Besides, there are no humidity sensors on the copier. There is a humidity switch to reduce humidity, but no sensors to notify any levels.
Anyway, the code is: 5,8 (simultaneously) - ADDITIONAL FUNCTIONS - 5,8 (simultaneously) - ADDITIONAL FUNCTIONS.
Oct 23, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
246 people viewed this question
old marine
old marine
