Question about Dynex 32 in. LCD Flat-Panel HDTV
I have had this 32" dynex lcd tv for a little over a year now and just the other day I had turned it on and about 30 mins later all the dark colors switched to white. It now looks like im looking at the negative of the picture. There are no colors just white and grey pretty much. I have tried to reset it with no luck. I have played with brightness and contrast but it doesnt change the picture at all. Any help is greatly appreciated.
I have that problem as well. well for the top 1/3 of the screen. the bottom 2/3 of the screen is vertical colored lines and a black background.
here is a link to a tv that looks just like mine with the same problem! ps. dynex wont help because my 1 year wannarty just ran outl. and best buy was useless. they offered me a $50 gift card! i want my kids tv fixed. they said there was a recall of the same sized tv but different model numnber but not my tv because they hadnt received "enough complaints!" can you believe it! ugh.
here is the link. this is some ones tv i saw on here who is having the same problem.
http://www.dumpt.com/img/viewer.php?file=x7akai1zbwvhpxrkxco7.jpg
Posted on Jun 12, 2010
I need to hook up a 3 way switch
Posted on May 01, 2010
Dynex 32' tv
Could be many thing. Likely war is 1 year. Contact mfc to see if they can help. 32 in Dynex is cheaper to replace. As far as diagnosis it would only be a guess without putting set on bench.
Oct 02, 2013 | Televison & Video
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
Dynex 32 in only shows black and white now
Black and White on a new setup would indicate you've plugged in AV or Component cables incorrectly. Match the colors up, be aware some Dynex models have AV connections on the SIDE of the TV. Don't just plug colors into random places. Failing that, check to see if your still inside 1 year manufacturer warranty or a best buy product protection plan. If not, seek out repair locally.
May 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 lcd hdtv L32-10C color is flashing green and purple
Just go to the service center where you bought that tv ,cause its ,one year warranty period. just consult your tv to the costomer service personel.
Jun 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Dynex 32" LCD - bottom 2/3 of screen is black w/ colored lines
My screen looks EXACTLY like that! I called Dynex and they told me my warranty is out and they cant fix it. I have only had this TV a bit over a year. Did you get a resolution??
Jun 02, 2010 | Dynex DX-LCD32-09 LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Straight out of the box had 3 pixels out, Now 2 days later a Black Circle.
The white spots are called 'dead pixels' and depending on the manufacturer, they may allow a certain number of them but normally not in the primary viewing area.
The other anomaly shouldn't be there and LCD displays are not affected by magnetic fields as are CRTs.
Return it quickly and I would be reluctant to accept a simple exchange.
Do some checking on the Dynex brand before you take it back though to see if this kind of quality is common to the make.
You might start here:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=dynex+lcd+problems
Jul 06, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
802 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
