Question about Garmin nuvi 200W GPS Receiver
My nuvi 205 touch screen is acting up
Some buttons work and some dont when i touch where to go it just goes boing then nothing. hit maps button and sends me to time settings help
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
Garmin Nuvi 205 comes on and shows street map, but touch screen is not responding
Restore the device, usually the garmin Gps have a little button in the back.
Aug 30, 2011 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 - when I switch it on the maps load up and after the warning screen a screen appears with the message "Stay up to date with your Garmon Safety Camera Data at my.garmin.com" I try...
You probably need to update the unit at their website. In the meantime, you can try the reset button There is one, but it's kind of stealth - it's on the angled edge of the bottom of the device, in a square "hole". Pressing the corner of the screen resets user data only, not the actual device. Good luck!
Apr 29, 2011 | Garmin nuvi 205 GPS Receiver
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
My touch screen will not work anymore. I tried
May I recommend performing a 'Hard Reset' (different from the reset button), or replacing the firmware of your Nuvi 205?
Both actions have been known to solve the symptoms you are reporting.
I hope that helps.
Mar 16, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin says no detailed maps found that support routing? It will not go away and the reset I tried didn't work. ???
Did you try a Hard Reset, or just push the button on the bottom of your Garmin Nuvi 205?
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Jan 30, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin Nuvi 205 just has a blank white screen. I just took it out of the box and read the directions and plugged it in for the first time. I've hit the reset button.
I hope that helps.
Dec 27, 2009 | Garmin nuvi 250W GPS Receiver
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
GPS would not turn on
Have you already tried the webupdater or registred the device on garmin.com? There you should get an free mapupdate which could replace your broken maps.
Dec 01, 2008 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
