Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
My tv turns off by itself. it doesn't reset just turns off. sometimes its after an hour sometimes its after a couple of minutes. I replaced the lamp and still the samething All 3 lights start to flash. Sometimes the picture goes out before the tv turns itself off.Any ideas. Please help
  • 6 more comments
  • Ahmose Avin
    Ahmose Avin May 07, 2010
    there are no signs of any bad caps. Could it be the thermastat or anything.
  • Ahmose Avin
    ok I hear the ballast start up and then a whining noise. not sure if its the ballast board or the color wheel. the tv was on for a minute just now and turned off. the whining noise starts when the tv turns on and when the tv turns off the whining noise goes away.
  • Ahmose Avin
    any ideas. the whining is very quite not loud at all. it sounds like its coming from the ballast board or is that just an echo. the color wheel spins fine and doesn't stop at all
  • Ahmose Avin
    Ahmose Avin May 08, 2010
    ok. I know for sure the lamp is good. what is the part # for the color wheel please.
  • Ahmose Avin
    so thats the most common problem with these tv's minus the lamp.
  • Ahmose Avin
    ok and whats that. the 2 tips
  • Ahmose Avin
    ok thank you for all of your help.
  • Ahmose Avin
    Ahmose Avin May 20, 2010
    Hi, can anyone one help me with this issue. I have replaced the lamp and the colorwheel. Still the tv shuts off on me and all 3 lights start to blink. Any ideas
    Top Expert:
  • Samsung Master
  • 14,553 Answers
As someone else suggested to you the color wheel if original is the most likely reason for this.
This has a small electric motor and spins at about 14,000 rpm. A typical failure of this part will be a high pitched sound or a fan like noise---the wheel faces the lamp and is close enough to the ballast for the sound to be difficult to pinpoint.
Problems where a set shuts down after some period of time can be hard to isolate but the description suggests it is the color wheel------it is plugged and connected to the sets light engine which will instantly detect if it slows down below a certain speed or even stops.
If the picture looks normal when it is on and the lamp is known to be good BUT hear the whine or fan like noise the color wheel is suspect.
I can look and get you a part number and cost etc and You Tube has actual video instructions for replacing them in most of the Samsung sets.
Let me know if you have questions--I am here to help and have changed a lot of these color wheels in this type and brand of set.
SD TECH
Posted on May 08, 2010
  • 2 more comments
  • SD Tech
    SD Tech May 08, 2010
    Part NumberBP96-00250A
    It is one of two types that failed the most.
    SD TECH
  • SD Tech
    YES, I have replaced more bad color wheels than lamps but the lamp is very easy to replace and not all people wish to attempt the color wheel If you replace it I have two tips when you do it to avoid common mistakes that the instructions on the web do not tell you about.
    SD TECH
  • SD Tech
    Aside from being careful when you replace it there are two common mistakes to avoid.
    1) The color wheel has two plugs that connect it to the DMD assembly which is part of the light engine; one is a small plug with a few wires but you have to be very careful removing it not to break the wires off and get it and the plug out. The second cable is a flat ribbon cable and only has contacts on ONE side and it is easy to plug it in backwards; most of these sets the contacts are facing the rear of the set and you need to be careful to get it back in correctly.
    2) Some but not all these sets after replacing the wheel the set will operate but the color look odd with a blue or other hue in the color----if this happens you will need to locate a small jumper on the DMD which is the metal box attached to back of the light engine and remove it (is small and pulls out).
    I have seen people who made one or more of these mistakes come to this site for help.
    I learned about the flat ribbon cable the first time I replaced one by getting it in backwards and of course the set detected the wheel was not connected and shut down.
    SD TECH
  • SD Tech
    Bookmark this page and if you have problems during or after the installation contact me here and I will assist you.
    Ebay if you are in a rush often has people selling this part and just search by the part number.
    SD TECH
    Guru:
  • 416 Answers
You may have a bad power supply and lamp ballast (most cases, the power supply damaged the ballast). You will need to take the back cover off the TV and inspect the ballast, specifically the capacitor on the ballast. The lamp is powered by this board, so it will be near by, just follow the red wires. A picture is provided below:
If the capacitor is swollen on top, this is a clear indicator of failure. If you only replace the ballast and not the power supply (SMPS) the problem will reoccur fairly quickly... usually within a few days the ballast will be damaged again. If you want to reduce your repair costs, you could replaced the power supply and the 47uF, 450v capacitor on the ballast.
Let me know what you find.
Posted on May 07, 2010
  • Adam Halfhill
    Adam Halfhill May 07, 2010
    Use the white and blue wire that connects to the lamp door switch, to trip the switch... that is, wrap it around it so the switch is held upward (closed). Listen to the TV while it is ON, does it sound abnormal. We need to make sure your color wheel is not the cause. The sound of it can be scratchy or shrill like when they are failing.
  • Adam Halfhill
    Adam Halfhill May 09, 2010
    Sorry for the delay on this post. If you have the lamp door off, and have wrapped the white and blue wire around the lamp door switch so that the TV can power up without shutting down in protection mode... run it for a while. See if the TV is shutting down. There are a few Samsung modes that are very picky with the way you install the lamp door. If you install it incorrectly, after a time, the warmth of the lamp will cause the TV to expand slightly and the lamp cover shifts just enough to disengage the lamp door switch, causing the TV to shut down. If this is the case, you must install the lamp in a swinging motion... as if the bottom of the door were hinged, and swing the door inward from the top. This will engage the lamp switch in downward position. Let me know.
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
My tv turns for a couple of minutes then truns off by itself...the red light blinks on and the green light that say timer and lamp also blink...help how do i fix it?
The projection lamp on this tv,when was it was last change?The last time change was about 1 1/2 or 2 years,and tv on an used at 4 or 5 hours a day.The lamp life is over,require a new projection lamp.
Jul 10, 2010 | Akai PT61DL34 Television
TV will not turn on. Lamp indicator light blinks
Replace Lamp (L3) # BP96-00826A (L6 )BP96-01073A Call Mats Electronics $99.95
1-800-628-1118
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Just replaced the bulb .it is working fine for couple of days..now it won't turn on,the lights just blink and turn off by itself
take out bulb and put in freezer for 5 minutes. then when unit comes on, go into menu and select lamp setting. it will ask have you replaced bulb? select yes and lamp timer will reset to zero hours
Oct 30, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Mar 05, 2008 | Sharp (BQCPGC20X1) Projector Lamp for...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
