Question about Teac CD-X8 CD Shelf System
I am unable to get power to the subwoofer. I tried everything, double checked the connections, checked the pins in the cable to ensure they were lined up correctly, tried it in different outlets but still no power. Had not used the system for about four months.
  • 3 Answers
Try ur internal fuses
Posted on May 01, 2010
Not getting any output from subwoofer, all connections are right,everything is on.
DOUBLE CHECK YOUR RCA CABLES. MAKE SURE THEY R GOOD & THAT THIER IN THE RIGHT SPOT ON THE AMP AND RADIO DECK.IF YOUR LIGHTS COME ON. THEN TRY THIS........ IF THAT DOES NOT WORK. CHECK TO SEE IF YOUR SUBS R CONN IN THE SUB BOX.IT COULD B SOMETHING THAT SMALL
May 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a "12 kicker
If it is the amplifier that is shutting on and off:
Check to make sure the power and ground wires for the amp are secure, with no fraying, knicks or exposed wire. Check your fuses and connections to make sure everything is correct. Also look at the grounding location. be sure there is exposed metal around the grounding point (paint may cause intermittent power problems). Lastly, the amplifier's remote wire may be improperly secured to the wiring harness. Check the harness for exposed wire grounding out connections.
If the amplifier is continuously on, the subwoofer may be to blame. Check and double check wiring schematics to ensure correct ohms rating.
Feb 28, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
Dvd writer doesnot showing in bios
Theres' a couple things you need to double check. If you also have a CD-ROM drive connected to the same data cable as the DVD-ROM writer check the jumper on the back side of both. One should be pinned with a two pin jumper and set as a master and the second should be set as the slave. The back side of each ROM drive is marked M for Master, S for Slave & C for cable select. (Cable Select not suggested).
Double check the data cable. Remove and re-seat at the motherboard and at the ROM drives Parallel ATA data cable. Also check the power cable. Remove and re-seat. If everything is connected and the two pin jumper correctly and snug you should see the DVD listed in the BIOS.
Performed a restart and check your BIOS.
Cheers'
Mike
Jul 20, 2010 | ASUS K8S-MX Motherboard
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
Thanks for the response. I installed the audio cable but still no sound. Any other suggestions?? Checked the device manager and it tells me that the dvd is functioning properly.
First guess, ensure the speakers are powered, double check all connections. Ensure that all audio drivers are installed in the device manager, or try installing the drivers for audio from Dell's website. You can search via your Dell service tag to provide drivers for your PC.
Ensure the volume control for Windows is turned up and not muted, and ensure the volume on the speakers.
Are you trying to play an audio CD from the DVD drive? If so, it may require a 4 pin analog cd audio cable which goes from the DVD drive to the sound card.
Oct 31, 2009 | Dell Dimension 8400 PC Desktop
New motherboard won't power up
First check your motherbord POWER pin it is in corner of motherbord.
Just short that 2 pin with screw driver .
Read on motherbord corner you can find pin for Power up.
also reconnect cable from psu to motherbord.
Aug 01, 2009 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
Unable to print to HP3055 connected through network. Has orange light on the back. All of the lights on netgear switch going crazy, but go normal if I unplug HP3055. Worked perfectly until yesterday when...
check the cable with cable tester ensure good or try with another cable
there is an ip address setting pls check it
if the printer in warranty period try with hp
Jul 15, 2009 | HP LaserJet 3055 All-In-One Printer
No power to control unit
Basically your service did not add anything I had not tried already. I had to send the product back.
I would like a refund.
Apr 10, 2008 | Audio Players & Recorders
Teac CD-X8 CD Shelf System Logo
278 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
